This is a discussion thread titled "does this bushing look bad?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I just had a new set of Michelins installed and a wheel alignment performed, but I'm still experiencing some vibration. I'll be going in again today for a wheel rebalance but I'm concerned my problem may lie with a suspension component. When I was looking underneath I noticed that my right side steering bushing looked very greasy and seemed cocked up in contrast to the left side bushing. I can rotate both shafts with some effort (the right with a little less effort). I've posted a picture of the bushings and I was hoping someone could tell me if the right side bushing might appear as if it could be contributing to my road vibration. The left is essentially as I found it...the right had a fair amount of grease on it that I wiped away.
well thats just a boot for the grease. but you may need to get a new tie-rod end if that one is shot. the shouldn't be any play in it with the vehicle jacked up and you push and pull on the tire.
That's what surprised me when I inspected it. I could see into what I presume to be the grease cavity. I'll lift the truck up and see if I notice any play at the ends of the shafts. I don't hear any popping or clunking while driving but the steering wheel shimmies quite a bit, which is what made me think that the bushing was kaput.
Hey, don't get a set from the dealer. I have a set for an 00 which is the same as yours. They are brand new OEM in the package tie rods. Let me know if they are damaged we can get something worked out to get you a new pair!!! I don't have my 00 any more so I have absolutely no use for them.
Work in progress...
This is not a bushing per se, but an outer tie rod end which is a ball & socket joint. As mentioned, there should not be any lateral play in the joint. If the grease boot is torn, then you should replace the end, since there is not way to add grease.
You may also check when you under there, the steering rack bushing. I had my girl friend turn the wheel when I was under. I found all the play in the wheel was from those bushings.
2001 Toyota Tundra 2WD V8 SR5 X-Cab TRD Package, 2.5' Bilstein 5100 Adjustable Front Shocks, Rear Bilstein 5100 shocks, 1 1/4' Rear AAL, K&N Cold Air-intake FIPK GEN 2, K&N Blue Drycharger, JBA Headers, Gibson Dual Rear Split Exhaust, 16x10 American Eagle 186 Alloy, Mastercraft Courser A/T 285/75/16r
*Moto Metal M0951 Gloss Black 17 in. Alloys *SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
*Bilstein HD Shocks, F&R *Hellwig Rear Sway Bar & Helper Springs *TCS Poly Steering Rack Bushings *Wheeler's Front Sway Bar Bushings *Timbren SES Kit, Front & Rear *
Brakes:
*TRD Big Brake Kit (front) *
BAD BONEZ BJ
I lied, I have a set of upper ball joints left, not tie rods. I know I used to have a set but I must have installed them on my 00 when I had it. Sorry about that. They are likely around $45.00 each from the dealership
Work in progress...
