Measurements needed for 2nd-gen Tundra suspension
Need a hand here. Doesn't matter what configuration or package you have, but it needs to be stock off the lot. No lifts. Even better would be if you have a front shock sitting somewhere off the truck, without a coil mounted.
With the tire off the ground, how much chrome shaft is showing on a front shock?
What's the length from the bottom of the threaded pin (top of the shock) to the approximate center of the eye at the bottom of the shock?
What's the length of the body?
Please also post up if you have OME or Bilstein 5100 shocks and can take the same measurements on your parts.
Thanks,
Sean
