Just thought I would let you guys know we now have these available. In the past we had them made to order or ended up using someone's elses but we ran into supply issues so what better reason than to have your own and in-stock at all times .... with a lower price.
- Scott @ Camburg Engineering
Camburg Toyota Tundra 4wd ‘00-06 L/T Front Axle Set
Part Nbr = CAM-310031
Retail price = $549.00
- CNC machined from aerospace quality 4340 chromoly and heat-treated to 45-47 HRC
- Machined hob splines for precision fit
- Large radius machining to reduce potential stress risers under torsional loads
- Uses factory Toyota inner and outer CV joints
- Uses factory Toyota or aftermarket CV boots & clamps
- Fits Camburg Engineering long-travel kits and other suspension kits 3.5” wider per side
- Powder-coated black finish
