KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Is the Sequoia the only rear disc conversion available?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-23-2003, 05:10 PM
Inactive Account
alkemyst's Photo Albums
Last Online: 04-30-2003 01:32 AM
alkemyst is on a distinguished road.
Default Is the Sequoia the only rear disc conversion available?
My father has a V8 2000 Tundra, he just did the TSB for his front discs and there was nothing wrong with the rears except they will need shoes soon.
He is debating the rear disc conversion and the parts list is from what I gather (using pre-9/2002 Sequoia parts...there was a changeover).
Pull everything down to the axles then:
caliper 260.99
bracket 78.53
pad 60.98
rotors 106.88
bearing 178.62
Deflector 19.49
8 bolts 44.28
6 bolts 20.32
washers 9.7
snapring 6.1
seal 25.36
retainer 15.78
oil seal 7.59
gasket 2.61
above x 2
then
shim kit 18.78
fit kit 13.55
proportioning valve from aftermarket
new lines
Is this the best way to go? I don't know much about Toyotas so I am not sure if I searched well enough.
I did a rear disc conversion on my own car and it was pretty much: Caliper bracket, Caliper, Rotor, pads, Splash Shields (I left them off), Emerency Cables, 2 soft lines (I did Stainless steel), 4 line washers, pads and about 2 hours labor.
Also on the horizon he is thinking of more power and is looking at s/c, dual exhaust and the header packages but has told me the exhaust setups approach $2-$3k...ouch. The brakes are the most important now, then he will be looking into more options. He tows a 23' Dusky Open Fisherman pretty regularly.
Thanks
Chris
Moderators Note: The thread "Is the Sequoia the only rear disc conversion available?" has been moved to the Handling, Suspension & Brakes Forum for better exposure and replies. PM was sent to the thread starter of its relocation. --- Possum
Old 04-23-2003, 07:22 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: 08-26-2008 01:42 PM
DevinSixtySeven will become famous soon enough.
what proportioning valve would you use?
-sean
GFX by FreedomEagle50
Manual Hubs
WTB: Passenger side headlight housing and signal light housing, OEM Toyota, for 2000 Tundra
Old 04-23-2003, 10:17 PM
Inactive Account
I am not sure yet, proportioning valves aren't that complicated and I'd try to find one with the same thread pattern, but reflanging brake lines isn't difficult.
I'd try to get one from a top level braking company though.
Old 04-23-2003, 10:23 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Last Online: 09-23-2006 09:21 AM
Why change the rear drums? I know, they're not sexy like discs, but don't they work OK? His big boat's trailer does have trailer brakes, doesn't it?
Ken
Old 04-24-2003, 03:50 PM
Inactive Account
I am not sure why he wants to change his exactly, I changed mine for two reasons: 1) way better pad than shoe selection 2) performance in the wet (south florida and a lot of puddles).
I know he gets alot of brake fade (maybe the tsb he just had done will fix that) especially with the boat and especially during the afternoon showers we have and with stop and go traffic almost everyday.
Plus changing pads is so much simpler that shoes.
Old 04-25-2003, 01:43 AM
thecarguy's Avatar
Inactive Account
thecarguy's Photo Albums
Last Online: 02-13-2004 05:40 PM
thecarguy is on a distinguished road.
Send a message via AIM to thecarguy
If I had a tundra I wouldent waste the time converting to a disc setup. drums get the job done just fine.
Old 04-25-2003, 01:51 AM
Inactive Account
davecsu's Photo Albums
Last Online: 06-11-2004 07:53 PM
davecsu is on a distinguished road.
Is there any added benefits to the rear disc instead of drum?
Old 04-25-2003, 09:20 AM
Inactive Account
Since you don't have a tundra how do you know?
Also that's not the point....one could say also a Tundra can pull just about anything it can tow, get to 60 mph just fine and looks functional from the factory...yet there are s/c, body kits, air intakes, etc.
As far as the benefit of disc brakes over drums, that is not the topic of my post. There are many, as well as disadvantages too. One would have to know the situation do determine the best brake for the job.
Some of the more practical benefits are way less fade, better wet braking, and much easier / cheaper maintenance.
On his truck you will not really be able to see the discs, he is doing it for better braking.
Old 04-25-2003, 04:58 PM
thecarguy's Avatar
Inactive Account
you can get drilled drums. You can even drill them yourself, but you will need to get them balenced afterwards.
Old 04-25-2003, 06:25 PM
Inactive Account
Old 04-25-2003, 06:28 PM
lelandstanford's Avatar
2005 Toyota Tacoma
lelandstanford's Photo Albums
Last Online: Today 02:49 PM
lelandstanford is on a distinguished road.
Are you getting more dry braking power? If you stump on the parking brake, will it lock-up the rear end?
2005 Tacoma AC 2WD 2.7L 5M
Old 04-26-2003, 08:55 AM
Inactive Account
In a drum setup if you are braking heavy going downhill (automatic without the ability to manually transbrake) you can heat up the rear drum setup enough that even the parking brake will not lock them up. With a disc setup you still may not be able to lock them, but you will have alot more ability to stop.
The main advantage is a disc 'clamps' and therefore the force can squeeze stronger (for a basic explaination), with a drum the force must expand to stop and the cylinders have only a limited range.
Maybe Tundra Solutions is the wrong forum to ask modification questions as it seems everyone thinks the trunk rolled out fine from the factory and one must be crazy to change things. Is there a more performance oriented Tundra site?
Old 04-26-2003, 01:35 PM
thecarguy's Avatar
Inactive Account
truck did not come fine from the factory, but the brakes are one thing that did. I used to have a 900 hp nova that had rear druns and it stopped just fine. Rear brakes arent really an issue. In cars and trucks the front brakes take care of 70% or the braking. Just get a high quality front pad (you dont even really need drilled, slotted rotors either) and a good solid rotor with plenty of vents around the circumfrence and youll be set.
Old 04-27-2003, 09:25 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
v8Toilet's Photo Albums
Last Online: 03-27-2008 08:05 PM
v8Toilet is on a distinguished road.
Pickup trucks don't really need that much braking power in the rear unless you are towing heavy loads. The main advantage of a disc brake over a drum brake is fade resistance. Drum brakes can stop just as well as disc brakes until they fade (get too hot).
On the Tundra the front brakes do most of the braking.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Dyno run 2 results click here
Old 04-27-2003, 09:58 PM
2005 Toyota Tacoma
Front brakes do most of the work allright. Mine do about 90%. Rear brakes are only good for parking.
I can jam on the pedal in rain then no lockup and no ABS modulation. Just a firm stop.
I can probably stop the truck quicker with my shoes than using parking brake alone.
My Tundra does not need Sequoia's rear discs. It needs Tacoma's front brakes.
