This is a discussion thread titled "HELP! my rear is gone tunv8 lim sl dif", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-15-2008, 12:20 PM
blade 25233's Avatar
Dealer : American Toyota
blade 25233's Photo Albums
Last Online: 10-25-2008 02:38 PM
blade 25233 is on a distinguished road.
Exclamation HELP! my rear is gone tunv8 lim sl dif
I need help!
In the last 3 miles my rear feels as if it's going to fall out around turns. I am not a mech. but am mech. inclined. I could really use an exploded view of a rear diff for my 2000 tundra trd off road lim slip. Does anyone know of any sites or books where I could get some how to's?
Also my truck is @ 79,124 w/ a new stock toy trans @ 65k per waranty repair.
Old 09-15-2008, 12:45 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
Default Re: HELP! my rear is gone tunv8 lim sl dif
Hope this helps! As far as the limited slip, disregard the pinion and side gears that go into the diff case. The limited slip replaces the open diff case and it's internals.
Mike - http://dyogim.blogspot.com
Old 09-15-2008, 03:16 PM
THANKS!!
That does help but after some calling around I found a new diff for $450 but I have to verify if I have 4:10 or what a dealers tells me at 3:91 gears. 3:91 runs $500-$600 est.
I pulled the diff. oil drain plug and found a healthy tooth. Does the tooth fairy leave money under the drive way?
Looks like it'll cost $800-$1000 to tow and replace if I get the diff my self
Old 09-15-2008, 03:30 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Originally Posted by blade 25233 View Post
THANKS!!
You can find used gears on here or on other toyota boards for cheap, maybe for $50-$75. Install will cost about $200. Unless you find a used/new(as you already have) diff then, it's just plug and play. Install is real easy.
Do you have 2WD or 4WD? If you have 2WD, don't worry about the gear ratio. You definitely have to match the front diff if you are 4WD.
Old 09-15-2008, 03:55 PM
4wd w/ trd offroad but it'll cost $280 for about 4hrs at an all toy shop.
I'm going to tow it over to the shop in the morning where they will verify the gearing which I hope is 4:10 or just a simple gear swap.
Old 09-20-2008, 04:57 PM
Hugemoose's Avatar
Dealer : Performance Motors Toyota
Hugemoose's Photo Albums
Last Online: Yesterday 08:10 PM
Hugemoose is on a distinguished road.
Send a message via AIM to Hugemoose
You're truck has 3.91 gears if it's a 2000. And if you have 4 wheel drive, as already mentioned you need to make sure they put the correct gears in the rear. Try looking at local salvage yards for any 2000-2006 Access Cab Tundra with a V-8....those should all have 3.91's gears in the rear. Double cabs have 4.10's.
David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/AAL~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Old 09-23-2008, 12:18 PM
It's all done. The local salvage yards don't have ANY Toyota trucks at all in town. I used a local mech to install called "TOYOMASTERS" who were kick ***. They charged me $423 to replace the guts/ 3rd member. DownTown Imports (salvage) ordered a 391 dif out of Pueblo Co. for $550.
When I seen the spider gears OUCH! The guy has been working on Toys since '83 and has never seen one do that before, ever.
Thanks for all the help guys!!!!!!!!!!!!!!!!! Hit me up if your ever in Albuquerque NM
