This is a discussion thread titled "Need to upgrade suspension... a few questions", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-05-2003, 01:08 PM
Inactive Account
GuardianED's Photo Albums
Last Online: 06-07-2006 08:22 PM
GuardianED is on a distinguished road.
Default Need to upgrade suspension... a few questions
I have a 2000 non-trd 4x4. I want to do something about the suspension; the black shocks are not doing it for me. I've read so much about troubles with coilovers tearing cv joints and what not, and I don't think I know if I should go that route. If I upgrade to red/blue TRD shocks, should I change my springs too? Or are the non-trd 4x4 springs pretty much the same as trd 4x4 springs. Thanks for the help.
Old 06-05-2003, 01:31 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
It's not that coilovers will cause damage to the CV boots. It's just lifting the front end past 2.5" will cause premature damage to the boots. If you stick with the lift at 2.5", it'll be all good.
Mike - http://dyogim.blogspot.com
Old 06-05-2003, 02:07 PM
TMS2U's Avatar
Dealer : Longo Toyota
TMS2U's Photo Albums
Last Online: Yesterday 06:47 PM
TMS2U is on a distinguished road.
ditto to that. Even if your cv's do leak a little, its VERY easy to remedy. The coil overs give a much improved ride over stock
Old 06-05-2003, 08:29 PM
Dealer : Carson Toyota Scion
2002 Toyota Tundra
Garrick62's Photo Albums
Last Online: 07-04-2007 03:34 AM
Garrick62 is on a distinguished road.
I am in the same boat as GuardianED. I want to know if going from the non-TRD 4x4 springs to the TRD springs will result in any lift? I like the idea of the red/blue shock being from bilstien (lifetime warranty, gas adjust and all). Anyone out ther done this before. 4x4 standard to TRD springs???
Old 06-05-2003, 10:36 PM
TMS2U's Avatar
minimal if any lift, just a stiffer spring rate
Old 06-06-2003, 05:47 PM
mgalios707's Avatar
Inactive Account
mgalios707's Photo Albums
Last Online: 11-01-2003 03:56 PM
mgalios707 is on a distinguished road.
Send a message via AIM to mgalios707
I have a 2000 tundra 4x4 non TRD version but installed a set of TRD progressive rate coils with the bilstein shocks all around. I also added a 2.5" daystar coil spacer and have noticed a significant ride improvement over stock, plus the truck is now even, not slanting down. i did need to replace the inner CV boots though because they were leaking grease and that was covered by my warranty. Hope this helps.
Mark
