05-08-2009, 06:52 PM
Last Online: 11-21-2009 08:21 PM
0
Downey Off-road Springs
Curious about the RCD lift for 06 DC 2wd, when you get the 5100's would changing the stock coil spring to a different one such as Downey be beneficial? This is what Downey has on the web for 00-06 tundra "The coil springs are a much heavier duty spring rate. We take Tacomas’ from 480 lbs. to 600 lbs. Tundra’s start at 600 lbs., we take them to 800 lbs." Any imput would thankx help
05-08-2009, 08:33 PM
Assistant Administrator
2005 Toyota Tundra AC 4.7L 4WD, 2004 Toyota RAV4 Sport 2.4L 2WD
Last Online: Today 08:30 AM
10
Re: Downey Off-road Springs
From my understanding, that would make for a very stiff pavement ride. VERY Stiff.
My Truck: 2005 Tundra , 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP. Suspension & Tires: 285/75-16 BFG T/A'ko , Fabtech Coils, 1.5" Wheeler's blocks , Toytec Diff Drop , 1.25" Spidertrax [front] , 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links , Wheeler's Anti-Sway Kit , Hellwig 7700 Swaybar , Timbren Rear SES
Electrical: URD MAF Sensor Calibrator , Superlift Truspeed Speed Sensor Re-Calibrator , ScangaugeII , Full LED Conversion
Stereo: Alpine CDA-9886 , Alpine & Phoenix Gold amps, Q-Logic box w/RF subs , eDead
Cosmetic: Line-X Bedliner , Custom N-Fab Steps , Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve , Debadged (partially ), Bell Truck Trunk, Access Vanish Tonneau
B e an organ & tissue donor, register at Donate Life
05-09-2009, 03:28 AM
Preferred Dealer
Last Online: Yesterday 03:03 PM
0
Originally Posted by
die
If you want to really take the RCD kit to the next level here is what I would suggest.
ICON Vehicle Dynamics
05-09-2009, 04:04 PM
Last Online: 10-31-2009 02:18 PM
12
800lb springs on a DC is going to SUCK!!! That will be a really rough ride.
If you put a winch bumper and 10,000lb winch on the front it would be fine, but unladen that thing is going to ride like a tank.
I had 750lb springs on my AC and it was a back breaker.
Get a set of ICONs if you want to get a better ride. They are a perfect fit and ride AWESOME on that DC with the RCD lift.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Linear Mode
© Copyright 2009 All rights reserved. TundraSolutions.com.
Other trademarks and brands are the property of their respective owners.
Use of this Web site constitutes acceptance of the TundraSolutions.com User Agreement and Privacy Policy.
Custom vBulletin Skin By
v7web.net
