Originally Posted by erikm
I've heard that the Camburg UCA's make a bunch of noise. Is this true?
Erik
Poly bushings can make noise...uniballs can make noise as well. I've never had a problem with squeaky uniballs in the control arm, only squeaky heims on the outer tie rod ends, and WD40 corrected the problem.
The most common squeaking is from the poly bushings many manufacturers have used for a long time.
I'm sure Camburg can add heims to your UCAs if you ask...they did for my 1st-gen LT kit. Just be aware, it will push the cost up. IVD arms cost more because of the hardware and labor for the heimed pivots.
-Sean
