Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 07-31-2009, 02:55 PM
Last Online: 11-10-2009 12:29 PM
jon745382 is on a distinguished road.
jon745382's Photo Albums
Default lift
i have some questions about leveling my tundra its a 2002 SR5 TRD 4wd. i was looking at using the BTS-7514 but only lifting 1.5 instead of the full 2.5 that way i dont have to change springs or use blocks in the rear. does the BTS-7514 come assembled ready to bolt in or not. if i only raise 1.5 do i need camburg or tc uca and do i need a diff drop. also what would be the largest tire i could run with out rubbing and what offset or backspacing would i need on the rim.
Old 08-03-2009, 02:15 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Default Re: lift
The 7514 is the complete eye-to-eye coilover, right?
You can certainly bring the front ride height up 1.5", and leave the rear suspension stock. Be aware of how you load the truck, tho...heavy items at the front of the bed, always, or you may find that it rides nose-high.
Sorry, not familiar enough with the parts to answer your assembly question. Easiest way to find out would be a quick call to Bilstein, or to the vendor you're looking at buying through.
-Sean
GFX by FreedomEagle50
Manual Hubs
