Re: Fox-Camburg setup on my truck
You should be able to keep the front sway bar with possibly some drop brackets for it or longer connecting rods since the factory lower control arm is retained. This setup is made for separate side articulation to allow for varying terrain. A sway bar would simply negate all the money spent on that type of suspension. If a lift is desired, but the truck will be primarily used on road, it would be better to spend the money on a different type lift. Of course, what would I know.... I went full long travel on a truck primarily operated on road. In short, you should be able to with some modifications.
P.S. good looking truck. I went with Camburg and Fox as well. Love it!
07 2wd SR5CM with 5.7 with some stuff done to it.
my pics
