I was getting ready to lubricate the propeller shaft of my 2004 Tundra ac when I notice that the manual calls for a molybdenum disulphide lithium base grease to use on double cardan joint. I looked around in 4 auto parts store and they didn't have any. Can I just use a regular lithium base grease?
Your help is greatly appreaciated. Thank you
Try a place that deals with Ranch and Farm Supply materials. It's important to use the correct grease and you can use it on the rest of the grease fittings on the driveshafts while you're at it.
Larry
Some people should not be allowed access to tools without books!!!
