Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 07-27-2003, 04:48 PM
bloodypulp's Avatar
Last Online: 03-09-2007 11:55 PM
bloodypulp is on a distinguished road.
bloodypulp's Photo Albums
Question replacing the rear leaves
i want to replace my rear leaf springs with something beefier, but not add-a-leaf. does anyone know what their oem leaf spring weight rate is? i want to spec a heavier set.
and has anyone tried replacing the rear leaf/shock setup with a coilover design? the reason i'm asking is because new coil springs cost a lot less than leaf springs.
thanks.
Old 07-27-2003, 05:49 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
Last Online: 11-27-2007 02:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers keiphers's Photo Albums
My new leaf springs (Fabtech) are much stronger than the OEM and were only like $65.
However, I remember one member mentioning adding a Sway-a-Way coilover to the rear. It might have been TMS2U.
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 07-27-2003, 07:57 PM
Lawaia's Avatar
Dealer : Waipahu Toyota
2002 Toyota Tundra
Last Online: 11-02-2009 05:01 PM
Lawaia is on a distinguished road.
Lawaia's Photo Albums
If I'm not mistaken, Gary from Wheelers has a leaf spring replacement and goes for about $490.00 or something close to that. Also Deaver Springs in Santa Ana has a replacement leaf spring for the Tundra, but I don't know how much they go for. I hope this helps a little.
Old 07-28-2003, 11:16 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Default Re: replacing the rear leaves
thanks.
good luck finding beefier coil springs that will easily mate to your stock axle...maybe you could use a seq or lc rear axle since they already have the coil perches. rear coilover setups are generally for unloaded, long travel applications (long narrow coils) or heavily laden short travel applications (short wide coils). the latter application will probably require a larger spring perch than the lc or seq rear, but its been a while since i looked at them.
i do not know the exact oem #, but i will say it is very weak--meant to ride gently with the bed unloaded = saggy rear when you put a load in there, heaven forbid you put in a full half ton (truck's working weight). youre correct in thinking that aal will not help you here.
switching to a coil setup in the rear will require custom fab, which if done proper will set you back significantly more than new leaf packs, since youll also need to fab axle locators (3-link, 4-link, or radius arms). this is definately not something youd want to booty fab with booger welds, at least not on a tundra.
see my photos for pics of an alcan spring replacement pack--+500#, +2.5", double-wrapped positive eye = 500$ shipping included... www.alcanspring.com does very good work. talk to tom if you call them. you spec the springs, they build them, ie you can say "stock eye to eye length, but 1" lift, and meant to carry +XXX# over the stock weight" and they will build them for you. usually takes a few weeks, but they are beautiful. if you get a set, remember to load the bed heavy for a day or two so it works the springs in, they don't shot peen them. the setup i have required longer u-bolts, also shown in the pics.
-sean
*edit* this is a long-travel (meant for articulation, not speed, but the coilover is similar) coilover application. looks like they finally flopped it good, competition and everything . here is a better flop, you can see the radius arms (and the competition boundary, which he's still inside ...that is a heavily modded 4runner btw). i dont have a good pic of a massive load-bearing coil, but the black canisters on a semi contain a load bearing spring...short and wide, meant to carry several tons. theyll ride like a buckboard empty, tho.
GFX by FreedomEagle50
Manual Hubs
Old 07-28-2003, 03:30 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
Deavers are what camburg uses in there rear setups. I think they run about $400 but I heard that they wont give you any extra spring rate.
