Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 08-01-2003, 06:50 PM
SHAMROCK's Avatar
Last Online: 12-01-2003 02:16 PM
SHAMROCK may have some regrets.
SHAMROCK's Photo Albums
Talking Wheeler's Coils
EXCELLENT !!! installed the coils last nite.... had some fun with the alignment of the mounts,, but,, these things did a world of improvement to the front end of this 2000 SR5 4X4 ! ... I am very pleased with the ride and stance... 2 1/2" lift on the frontend,,, now to tackle the rear a.a.l.'s from Carson T
Old 08-04-2003, 05:54 PM
Dealer : Findlay Toyota Flagstaff
Last Online: 04-21-2007 06:35 PM
Goombah may have some regrets.
Goombah's Photo Albums
Thanks for the info... looks like a good mod for leveling (without going spacer).
How's the ride? Did it get much stiffer?
Thanks
Old 08-05-2003, 10:34 AM
HockeyFreak's Avatar
Dealer : Leith Toyota
Last Online: 04-27-2009 07:06 AM
HockeyFreak may have some regrets.
Send a message via MSN to HockeyFreak HockeyFreak's Photo Albums
We need PICTURES!!!!!
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD* :cry:
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
Shawn
Southeast Region Forum
Old 08-05-2003, 01:38 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
Last Online: Today 07:03 AM
H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future. H2O_MAN has a brilliant future.
H2O_MAN's Photo Albums
Click HERE for pictures.
The trouble with Socialism is that eventually you run out of other people's money.
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 08-05-2003, 02:09 PM
Dealer : Conicelli Toyota Scion of Springfield
2002 Toyota Tundra
Last Online: 08-28-2008 07:17 PM
openspaces may have some regrets.
openspaces's Photo Albums
I believe pics of the installed set-up would be more helpful. (THe whole truck.. before/after, etc)
Old 08-05-2003, 02:28 PM
H2O_MAN's Avatar
Default CAN DO -
I'll put it together for you soon.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Old 08-07-2003, 11:27 AM
H2O_MAN's Avatar
Default updated
I have posted the before and after pic you requested, plus a few more.
CLICK HERE
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Old 08-11-2003, 09:19 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 06:17 PM
Verndog may have some regrets.
Verndog's Photo Albums
Default Wheelers install
I purchased a set of wheelers, and was going to have a local tire shop install since I don't have a spring compressor. They just informed me they will only mount the springs into the strut assy and I'll have to bring them in cause of liability on parts not bought there.
So can someone guide me to the easy route to remove both struts at once to take to have new springs mounted to blue/white Bilstiens??
I read remove lower 4 bolts on lower control arm...is this right and I can remove both at once and let sit for a couple of hours without bending anything?? Also reinstall tricks if applicable...
Thanx
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 08-11-2003, 10:07 PM
so40's Avatar
Dealer : Gray Daniels Toyota
2001 Toyota Tundra,
2007 Toyota Yaris "S" Sedan
Last Online: 01-10-2010 02:38 PM
so40 may have some regrets.
Send a message via ICQ to so40 so40's Photo Albums
Verndog... getting the coil/shock assembly off is pretty easy. Just jack her up, put stands under her and take the wheels off.
Then loosen the bottom nut (don't take the bolt out yet) and then take the three nuts off the top of the shock tower. Do not remove the center nut up top! Then with someone holding the assembly for you tap the bottom bolt out with a punch. I used a "ball joint knocker outer", southern for pickle fork, and stuck it between the top 2 coil turns and gently pulled up or down to keep the bottom bolt straight while removing it. Hope you can understand this!
Now take the assembly to your local shop and let them swap the coils. There is a good set of instructions and pictures to help with this in the Garage Section... Maintenance and Repair Bay...How To...Front Shock Service and Repair. This shows a picture of how to align the top studs up so that the shock will fit right at the bottom when you reinstall. But, this is the tricky part.
It didn't take me but about 30-40 minutes to get them off. I hope this helps you.
Mike
Experience is the best teacher, IF you can afford the tuition!
White 2001 4X4 LTD/TRD. Fog and map light mods. S&S Autochrome headers and Y-Pipe, ASP UD Pulley,SpinTech single/dual out with rear exit. PPD T-Body and Fuse covers. MT Classic ll's with 265X75X16 Maxxis Mudders, Wheelers front coils, RAS on rear springs & Ride Rite air springs. Powertrax No Slip Locker. Mobil 1 Synthetic throughout!
Old 08-11-2003, 10:53 PM
Verndog's Avatar
2003 Toyota Tundra
so40....finally found the section you posted. I still have a question. If the shop misses the 25 deg rotation to upper bolt hole location...(I assume they will) and lower bolt hole won't line up...can I just vise the flat on lower mount and gently use a pipe wrench to rotate upper pattern to the correct 25 degs...without hurting anything.
I would think other then the spring tension holding it, rotating is OK...correct??
Thanx
Kevin
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
Old 08-11-2003, 11:49 PM
Dealer : Fremont Toyota
2002 Toyota Tundra
Last Online: 03-16-2010 12:24 AM
Triple BB is on a distinguished road.
Triple BB's Photo Albums
Wonder if a few guys who dumped big bucks on coilover kits aren't wishing they would've waited a bit longer for something like these.
Old 08-12-2003, 11:51 AM
so40's Avatar
2001 Toyota Tundra,
Verndog...
I don't see why that wouldn't work as long as the rubber cushion doesn't start trying to "wad up" while twisting the top. I guess the only other way would be to compress it some and then turn it, but that would require the compressor. It is probably going to be tuff to turn though. Between the pressure from the coil and the grip of the cushion it will take a good bit of leverage, but I think you could do it.
Someone may know of a reason not to do that, but it looks to me like it should work. Depending on which way you have to turn it, make sure it doesn't move the end of the coil away from the spring "stop" at the bottom.
Mike
Old 08-12-2003, 02:53 PM
Dealer : Carson Toyota Scion
Last Online: 10-27-2009 03:27 PM
Alan may have some regrets.
Alan's Photo Albums
Lightbulb Match mark everything
Vern,
I’m not familiar with the parts you’re installing, but when I took my shock assemblies to the shop for installation of my spacers, I match marked my coils and my shocks with paint to reference the original orientations. Then you can check right there before leaving that everything is aligned and stacked up just how you want it.
My two cents,
Old 08-12-2003, 03:42 PM
ZIGGY454's Avatar
Dealer : Rockingham Toyota
2002 Toyota Tundra
Last Online: 03-11-2010 02:01 PM
ZIGGY454 may have some regrets.
ZIGGY454's Photo Albums
Shamrock, Just got off the phone with Gary from wheelers and ordered my set of coils. I really apprieciate people like yourself who take the time to inject their experiences and this site for reserching and to be able to get real feedback from everyday people in the real world who expierience these products first hand !! Anybody else have good results please pipe in on this forum if you will. Shamrock; did you have a spring shop install the coils or did you rent a coil spring compressor? I am going to rent a external spring compressor and istall these bad boy's myself. Any other hints or recomendations you can pass on would be greatly appreitiated.
ZIGGY
Old 08-12-2003, 08:40 PM
so40's Avatar
2001 Toyota Tundra,
Default Good Idea
Alan,
you are correct about marking them before having them changed. I started to do that but since a Toyota dealer was doing this for me I figured it wasn't necessary. However, they got the right side just right but I had to take the left side back twice before they got it correct. At least it didn't cost me anything.
