Noticeable positive camber, 1 wheel only but drives straight
+ Reply to Thread
Results 1 to 2 of 2
Thread: Noticeable positive camber, 1 wheel only but drives straight
  1. #1
    Rookie gtkid is on a distinguished road.
    Join Date
    Jul 2010
    Location
    Nashua
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Noticeable positive camber, 1 wheel only but drives straight
    I installed an LRO 3/1 kit and then had it aligned with the factory 18's by a reputable shop. I noticed the drivers side front tire had very noticeable positive camber (unsure of numbers) while the passenger side looked to be as close to 0 degrees as possible by eye. The truck drives as straight as can be with no vibrations. I just put on a set of 18" monsters with 295 Nitto's and it still drives straight but now has a very slight wobble at 60mph, but I am more concerned about premature tire wear.
    With just the 1 side with noticeable positive camber is this cause for concern as long as it drives straight?
    It's a 2008 DC w/ TRD Off Road pkg
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    48 times
    Images
    22
    Rep Power
    34450
    Default Re: Noticeable positive camber, 1 wheel only but drives straight
    I'm not DJ, but here's an opinion...
    It will affect how the truck handles.
    The big question I guess I'd have...is that a drop kit or a lift kit? I'm not familiar with the parts. Before going back to the alignment shop, make sure everything is installed correctly.
    There's no reason a trained tech with a modern alignment rack and a late model vehicle cannot hit the same numbers on both sides to within hundredths of a degree, even on a fully custom setup. If your parts are installed properly and are not defective, then they should be able to make both sides the same, whatever those numbers may be.
    Toe is what wears tires quickly...too much or improper toe will wear out a good tire in a season, and make the truck squirrely. A big difference in camber between sides will make the truck handle different in turns, but my guess is you'll have to be giving it good to notice the difference. Wear from excessive camber...I have noticeably negative camber on my truck, and my tires are wearing great.
    Personally, having one number noticeably out like that makes me suspect the rest of the job. I would look at the numbers, take it back in, and tell them this:
    Set caster at the highest value in the factory-acceptable range.
    Set camber and toe at the factory-recommended value.
    Set each measurement dead equal side to side, no exceptions and no excuses, dead equal. The specifications are not side-specific, they should be exactly the same.
    It will ride like it's on glass. The above advice is from DJ, boiled down and applied to your model year.
    -Sean
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
