I don't know if it helps or not, but RCD sent a brochure of a 6" lift system. There are pics of a lifted Tundra on the brochure. Maybe they are getting closer. RCD is pretty much the lift I've decided to go with too.
2000 SR5 4.7L 4x4 Tundra w/daystar level kit and add a leaf rear,Three inch body lift,Eagle Alloy 16x10 wheels,315/75/16,Pioneer dvd gps system,Front clear corner lamps,rear Altezza tail lamps,40s flowmaster mufflers single in dual out,Stone mountain headers,Helix thottle body spacer,K&N cool air intake system,Dyno-214 hp at rear wheels,Viper alarm W/remote start,Cobra radar detector,And to top it off,my Tundra has a B!tchin driver. My website www.truckinutz.com
They have a brochure, but thats it. They say end of the year at the earliest. I have had the brochure for about 4-5 months, so don't get your hopes up.
That s***s I have been thinking about giving them a call . I wanted to see what other options were available other than blocks for the rear. I guess I have two questions now. The rear and WHEN????
So does that mean they have the lift for the front ?
This company is killing me...I remember back in jan at a off road show in pomona, I saw their white tundra with the 6 inch lift...what the hell is taking so long ???
The problem with the tuff lift was that the spindle would snap. They're redesigning the kit with a new stronger spindle, that won't be out for a couple months. If RCD doesn't hurry the heck up I'm gonna get the tuff lift instead.
Rcd lifts on fords come with new hefty long spindals so upper control arm stays in same position and links and tie rods,only thing that moves is the tranfer and the lower control arms.I have installed two kits on f150s,and I must say I like that.The lift on the white tundra for rcd has different spindal and from what I saw on the pics they are nice and hefty.Im sold.WHEN WILL THEY COME OUT WITH IT-WE CANT WAIT ANYMORE.TS HELP!The only thing is that yes the pic was a 2wd tundra-now-to lift the truck you have to lower the tranfer case but the front drive shaft goes over the rack&pinion.Ok what happens-does the rack go lower or the drive shaft go under the rack?
Any answers
Chris
Hey guys, why not call up fabtech or CST and see if they will make a spindle kit, tell them how RCD is toying around and that tundra/tacoma/sequoia owners will buy them.
Or go to a custom shop like camburg or pro trucks and see if they can fab up some custom spindles. Im guessing here but a custom set of spindles (not the most badass ones, just somthing decent) will run about $1200, if you guys get a group together you could get it much less. Just some thoughts.
