Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 10-22-2003, 07:45 PM
ElSanTT's Avatar
Dealer : Toyota Scion of El Cajon
Last Online: 07-21-2008 10:25 PM
ElSanTT may have some regrets.
Send a message via AIM to ElSanTT Send a message via MSN to ElSanTT ElSanTT's Photo Albums
Default Save $7000 but can't decide on what kind of lift?
Hello there TS users, I got a problem here. I got a 2001 SR5 2WD Tundra and I do some mild off-roading. Also I have 7000 dollars to spend on a suspension lift and tires/wheels combo. I just can't decide on a lft. I've read the Offroad FAQ and search on this site like forever but I am still debating on a kind of lift. I keep on changing my mind. The main focus is that should I get the long travel kit and get 33's or wait for the RCD lift and get 35 inch tires? Also to add, JD Fabrication might be coming out a long travel kit for the Tundra but I am leaning toward a higher lift like RCD. NO Body Lift! I don't want to have any regrets. Any advice would be awesome. Thanks
Old 10-22-2003, 08:06 PM
1spiffyTRD's Avatar
Dealer : Torrance Toyota
2002 Toyota Tundra
Last Online: 12-15-2009 01:57 AM
1spiffyTRD may have some regrets.
Send a message via AIM to 1spiffyTRD 1spiffyTRD's Photo Albums
The RCD kit wont be great off-road. Im sure you can fit 35's on LT kit w/ a pre-runner bumper. The RCD kit sounds good, Its more of a 6" lift than a off-road suspension system. Long Travel is sweet. Ive seen some good work by JD fab, but I dont know what shocks they are gonna use. I regret getting 33's. Cant do much with them off-road. 35" is the perfect off-road tire. I also regret getting my lift, I just got it 2 weeks ago by the way. I should have got the LT kit instead. Hopefully I can incorporate my lift with some more parts to make it an LT suspension. I already have the total chaos uppers and the Kings, hopefully I can get my hands on some lower control arms, bumpstops, upper heim shock mount, and a steering extension. With that, fiberglass, and the pre-runner bumper Im gonna run 35's.
2002 Toyota Tundra TRD
4.7L V8 |Total Chaos Long Travel | 35" Goodyear MT/R's | Stock Rear
Old 10-22-2003, 08:41 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 10:15 AM
Images: 22
DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light. DevinSixtySeven is a glorious beacon of light.
i'd say the best response may be from the rcd guy on the rcd lift kit thread...where he says the total chaos kit is a step up from the rcd. if you had a 4wd, i'd suggest leaning toward the rcd kit or some custom work, but since you're in prerunner mode, the total chaos and camburg kits would set you up real sweet. i doubt you'd have any regrets with either, also i doubt you'd have any regrets with the rcd lift, but like i said since youre headed the prerunner route, i'd look at long travel. 7k is good for either kit, plus fenders, tires and wheels, installation, and maybe enough left over for a prerunner bar. there are several l/t trucks around here, hopefully they'll post, i don't have any experience with the long-travel kits.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 10-22-2003, 08:54 PM
ElSanTT's Avatar
One of my main concerns of the long travel kit is all this fabrication and changing the look. Though it is a kisk *** look, it may just fade out from interest. Also, I only do some mild offroading, probably couple of times every 3 months. With the RCD lift, the only change is the suspension but with long travel you change alot of things. I'm very indecisive but i just want to make sure.
