This is a discussion thread titled "'03 CV boot question:", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I was going to do the CV boot mod, with hose clamps, but when I looked at my CV boots they already have metal bands around each end. Is this something that pre-'03's didn't have? Should I remove the bands and replace them with hose-clamps, or is that just redundant?
Planning on using a 4" clamp on the large end and a 2" on the small end of the CV boots.
Haven't had any problems since my 2" lift, but just want to be safer instead of sorrier.
I have a 4X4 and have a king coil over lift on the front only.
I lifted it about 2 1/4" inches.
I only have 900 miles on it since the lift.
The boots didn't leak until I put the 4 wheel drive
system to use.
After that the upper boots leaked at the upper band.
The boots were't torn, the factory band is just not tight enough.
You could squeeze grease out with your finger.
I had the bands replaced with real clamps the other day.
It looks a lot tighter and feels tighter.
The clamps are a bit tricky to get off since you don't want
to damage the boot.
Took about 45-1 hour to do.
Take your time doing it.
Only have about125 miles since the clamp/band conversion.
I'll let you know down the road how it worked out.
If you don't want to do it yourself, where do you live and they're
might be someone out there who will do it.
system to use.
to damage the boot.
the mad surfer
Thanks, that's all I needed to hear. I'll do the boot mod before I use 4x, hopefully this week.
just use pliers and squeeze the clamp section together, it'll release with a little wiggling.
Yeah, it looked like a tension clamp to me. Doing this mod tomorrow, don't really need it, I think, (less than 2" lift), but I am really uptight about preventing damage to my truck before it has a chance to happen.
i've put my 4X4 to use twice this month, some serious wheeling, and some just cruising, and the boots haven't leaked at all. Sounds like that fixed the problem.
I used regular hose clamps.
nothing special.
also if you just did it,
there's a lot of talk about how under full
droop/compression there's a clunking noise.
you might want to look into all that as well.
it's under suspension/handling entitled, clunking noise
w/ king coilovers
Thanks "TheMadSurfer." Yeah, I read the posts about the clunking problem. Haven't really tested it yet but so far so good. The shop that installed the Kings couldn't say enough good things about them. The ride is far superior to stock. I found the stock setup too soft. I put 9000's out back to stiffen it as well.
2001 Tundra Limited 4X4
Tuff Country 4" lift, Kings 2.5" coilovers
Goodyear MTR 315/75/R16 on Ultra 16X8's
Pioneer DEH-P7300 CD player/changer controller
Pioneer DEQ-7600 Graphic Equalizer
Pioneer CDX-P1270 12 disc changer
Rockford Fosgate 250.2 Sub amp
JL Audio 8W3V2 4 ohm DVC Subs (2)
QLogic sub enclosure
Stull grill
Galaxy DX95T
Wilson 1000
