Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 12-16-2003, 11:13 PM
Dealer : Cavender Toyota
Last Online: 09-22-2008 01:47 PM
Lightning is on a distinguished road.
Lightning's Photo Albums
Default Question about cruise control
While I was driving my 2001 Tundra 4x4 V8 in a 55 mph zone in cruise control mode, I approached a downhill part (not too steep) of the road. To my surprise when I looked at speedometer at the bottom of the hill, I was going 63-64 mph! And once the road leveled, it came back to 55 mph and stayed there. I always thought that cruise controls maintained your speed, regardless of up or down grade (to a reasonable degree). Has anyone else noticed this? On other roads, when I'm going 70 mph in cruise control, it usually maintains 70 mph, up or down grade (although I hate the constant downshifting on uphills). I'm guessing at 70 mph, there's enough wind resistance to keep the truck at around 70 mph (unless it's a really steep downgrade), and maybe at 55 mph, gravity can still overcome the wind resistance, and let the truck speed up? But then again, I always thought cruise controls held your speed constant...
Tundra LTD TRD AC V8 4wd White
Old 12-17-2003, 12:15 AM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
All the cruise control can do on a steepish downhill is close the throttle. If the hill is steep enough...or if there isn't enough wind resistance...or if you're close to the speed at which the transmission's torque converter in OD will unlock and freewheel (or doesn't generate much engine braking when locked), then gravity will indeed speed you up significantly. I encounter this quite a bit here in Colorado with our mountain grades, particularly on the 2 lane roads with 50 to 60 mph speed limits.
The easiest way I've found to solve the problem is to keep an eye on your speedometer during descents and if the speed starts to increase while using the cruise control, just turn off the overdrive. The transmission will go into 3rd and the torque converter will lockup to provide quite a bit of engine braking...enough that the cruise control will be able to maintain the set speed. At the bottom of the hill, just turn OD back on and go your merry way.
Ray
Old 12-19-2003, 01:24 AM
Thanks for the info! I feel better now, knowing there's nothing wrong with my truck's cruise control. I just wish they would eliminate the annoying frequent downshifting that occurs when using cruise control in slightly hilly areas. This is the only car I've owned that downshifts so much in those conditions. During my long drives, it will downshift dozens of times, and it gets old really quick. Our engine is supposed to have a lot of low end torque; I'm guessing they do the downshifting to prevent 'lugging' the engine and to improve emissions; however, it can't be very good for the tranny in the long run.
Old 12-19-2003, 10:04 AM
2003 Toyota Tundra
Glad my explanation helped your understanding.
Totally agree with you on the excessive downshifting issue! And if you think it's annoying in relatively flat and low elevation Texas, I can testify that it's a lot more annoying when crossing Colorado's mountains...where the grades are steeper and the air is thinner (the engine has roughly only half its sea level torque). I've also discovered that doing a "resume" if you're more than about 1 mph below the set speed causes the same commotion. It also tends to overshoot the desired speed by as much as 2 mph before it finally settles down.
And no, that much downshifting under fairly full throttle is not helpful to long transmission life. It's bothersome to have to do it, but I've found that if I turn off the OD in hilly/mountainous areas then no problems.
The cause of the problem, I believe, is the ECU's logic for the cruise control is fairly aggressive and not very proportional to the difference between current speed and set speed (it opens the throttle fairly rapidly even if you're only one mph below set). Plus, on a relatively pricey vehicle like this one, it could use additional inputs such as the accelerometer that's in the Prodigy brake controller so the truck would know how steep a hill you're on. A controller with "fuzzy logic" might help this thing...as cruise control "brains" go this one isn't the sharpest tool in the drawer. But given that the truck really has very few other bad traits, I'm willing to put up with this one.
Ray
Old 01-22-2004, 11:01 PM
Dealer : Earnhardt Toyota
Last Online: 07-19-2007 11:56 PM
AZ TUNDRA is on a distinguished road.
AZ TUNDRA's Photo Albums
This down shifting is just a pain! Does anyone on the TS Forum work for Toyota or know someone at the factory that could reprogram whatever is making the transmisson downshift and fix the problem for all of us?
Old 01-22-2004, 11:14 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Thats what I do if its starts kicking in/out of OD, when the road flattens back out just kick it off.
Seems like the truck used to do this ALOT more when it was newer, but as the miles rack up it hasnt been so much of a problem.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 01-25-2004, 12:17 AM
Last Online: 05-30-2005 11:08 AM
Mark440 is on a distinguished road.
Mark440's Photo Albums
I've made the trip from Dallas to Shreveport more than a few times. I set the cruise at 78....and it stays within 1 mph all the way...hills or not. It usually doesn't downshift at all.
I know...last thing you want to hear is somebody's stuff that is working ok....
Old 01-25-2004, 12:05 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
I would agree with this. Cruise control is at its best on the long flat streches. And because of the issues with maintaining speed, and shifting I just kick it off if I have varying types of terrain.
Also you will lose mileage using cruise on hills, because it over compensates trying to maintain exact speed, where as I would pick up 5mph at bottom of hill and keep constant gas and maybey lose a couple by top on a steep incline, just to conserve resourses. Its easier on the running gear and mileage, and when you live in hilly areas like I do makes complete sence.
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 01-25-2004, 12:09 PM
Verndog's Avatar
2003 Toyota Tundra
That is because of the year truck. The 03 and newer trucks have a higher emmisions level, and attempt to stay in the power band more to keep emmisions down. That is also why the ECU's changed in 03.
I believe both your trucks are working normal. Also at 78 MPH your closer to the power band and it will naturally shift less.
Kevin
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
