This is a discussion thread titled "Reason for Hose Clamp Mod??", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-22-2003, 01:52 PM
kelltl's Avatar
kelltl's Photo Albums
Last Online: 08-20-2008 05:20 PM
kelltl is on a distinguished road.
Default Reason for Hose Clamp Mod??
Hear me out guys......
I lifted the front using wheelers coils and now my boots are spitting grease. I have read all about the hose clamp mod that is being done for this and thats great. Here is what I am thinking though and I want you guys to comment on this: By lifting the front we are changing the angle of the CV joint and therefore changing the angle and interior space inside the CV boot. The grease spitting out is because there is no longer the same amount of interior space inside the boot due to the new angle. Since the interior space is less and the amount of grease the same, it spits grease out. Wouldn't it stand to reason that once the amount of grease inside the boot is equal to the amount of interior space inside the boot that it would stop spitting grease and we wouldn't need to do the mod? Opinions/Comments? I want you guys input before I go and do this mod.
Old 12-22-2003, 04:03 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 12:34 AM
your thinking is logical, however there's precious little space inside that boot to begin with.
also, when you flex the suspension, the boot will return to its original shape, but compressed now from the lack of fluid, i'd think either the baffles will suck together or it will draw in air/fluid to compensate. there's a lot of room for grease in the cv joint, but i'd clamp them down with as much grease inside as possible to prevent the boot from rubbing on itself or drawing in contaminants...course i could also be nuts...
-sean
GFX by FreedomEagle50
Manual Hubs
Old 12-22-2003, 05:40 PM
mike.elmes's Avatar
Dealer : Sun Toyota - Edmonton
mike.elmes's Photo Albums
Last Online: 09-03-2008 04:27 PM
mike.elmes is on a distinguished road.
The stock clamps on mine were loose...I could actually turn them on the boot. There was no way to tighten them either, so for the cost of 5 dollars a guy can replace the works with something that can be tightened. Great value.
mike
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
Old 12-26-2003, 07:31 PM
themadsurfer
Dealer : Kearny Mesa Toyota Scion
2003 Toyota Tundra
themadsurfer's Photo Albums
Last Online: 02-04-2008 07:59 PM
themadsurfer is on a distinguished road.
Default clamps
the stock ones on mine were loose as well, and you could spin them by hand as well, factory sht just doesn't cut it. I replaced them with actual hose clamps and no more problems
Old 12-27-2003, 12:16 AM
kelltl's Avatar
I did the hose clamp mod on mine today as well. I used a band type cv joint clamp but it uses a special tool to tighten them down. You can crank them down as tight as you want but they fit the groove on the boots just like the factory ones do. It was a little tricky getting them to stay completely tight while I backed the tool to tighten them off, but I got the hang of it on the second try. I may end up having to redo them one more time to get them tight enough as I was a little leary at first to really, really crank them down. Good option for those wanting to use "stock looking" clamps. The only reason I really care at all is if I take it in for warranty service I want no reason for questions.
Old 02-03-2004, 09:51 PM
dondi40here's Avatar
dondi40here's Photo Albums
Last Online: 07-11-2005 09:57 PM
dondi40here is on a distinguished road.
Where did you find the hose clamps that are thinner that are the same width as the clamps that are on the stock boots.
Old 02-04-2004, 08:49 PM
themadsurfer
2003 Toyota Tundra
off road shops should sell them, home depot had some but weren't excalty
the right size, dixiline has them, kragen might even carry them...
Old 02-05-2004, 03:13 AM
toy4play's Avatar
toy4play
Dealer : Toyota Carlsbad
2002 Toyota Tundra
toy4play's Photo Albums
Last Online: 07-26-2007 03:47 PM
toy4play is on a distinguished road.
is that mod in the mod thread? I guess I better pay my dues again.
Total Chaos upper "A" arms, Off Road Solutions hub conversion, Sway-A-Way (racerunner) coilovers w/ 3" lift, 1 1/4" Rancho rear blocks, Downey Headers, Flowmaster 40 series, MT Wheels, 285/75R-16 Nitto terra grapplers, clear corner front lenses, skid row skid plate, Pioneer stereo, 8" CDT subwoofers
Old 02-06-2004, 10:44 AM
themadsurfer
2003 Toyota Tundra
it should be somewhere.
Old 02-06-2004, 02:42 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Yesterday 03:28 PM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
CV BOOT MOD (Hose Clamp)
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 06-07-2004, 07:41 PM
Steelshot's Avatar
Dealer : Toyota of Santa Barbara
2002 Toyota Tundra
Steelshot's Photo Albums
Last Online: 09-26-2008 05:40 AM
Steelshot is on a distinguished road.
I've been monitoring my CV boots closely since installing a Cornfed 2" lift and a Total Chaos 1" diff drop. Still no problems with leaking grease, but was thinking of doing the boot mod anyway. Looked all over for narrow hose clamps and had almost given up. While waiting in line at Larry's Auto Parts in Goleta(www.Larrys8dayAutoParts.com) there they were. A whole row of various length narrow hose clamps. I asked the counter guy what they were for and he gave me the standard "don't you know anything?" look and said "CV boots". Haven't purchased any yet, but as soon as I measure the proper size for the Tundra I'll do the mod with these clamps. They look to fit inside the CV boot groove.
Ivan Stewart Body Kit; IS Wheels; Clear Corners w/ silverstar 3157A bulbs; Snug Top SuperSport cap; Marathon Super Hides seat covers in Shadow Grass; Husky floor liners; Toyota self-dimming rear-view mirror w/ temp & compass; Yakima Track Racks; debadged; Colgan front mask (only when going off-road); Cornfed 2 inch lift; Fabtech add-a-leaf; Total Chaos 1 inch differential drop kit; silver/blue TRD Offroad decal from Street Graphics.net; Line-X spray-in liner; 2005 tail lights; tailgate seal; Challenger Step Bars; Hellwig sway bar w/ Frontrange disconnects; SolidWiring Technology FOG603 foglamp mod & DRL601 switchable DRLs; battery manager; Prodigy brake controller.
Old 06-11-2004, 07:37 PM
themadsurfer
2003 Toyota Tundra
if it fits inside the groove then it'll work. It takes just a simple hose clamp to
make sure you wont be leaking grease. Well worth the effort to install the new clamps.
