front suspension
NEWS
+ Reply to Thread
Results 1 to 9 of 9
Thread: front suspension
  1. #1
    Rookie jptrout is on a distinguished road.
    Join Date
    Aug 2010
    Location
    utah
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default front suspension
    i could use a little help. my 2002 tundra has developed a klunck sound coming from the frt drivers side tire. it even does when going through city gutters and driveways. i know this is avery vague description. is it common for bushings to wear out at 85k miles or am i in bigger trouble. thanks for any tips that i get.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Rookie coorslight is on a distinguished road. coorslight's Avatar
    Join Date
    Mar 2010
    Location
    lake arrowhead
    Posts
    20
    Liked
    0 times
    Images
    5
    Rep Power
    3
    Default Re: front suspension
    its probably the ball joint or a steering component, but if you want to diagnose the problem your self its good to jack the front end up off the ground and wiggle the tire side to side and up and down to see if there to much play, or uncommon klunking. usually the up and down motion of the tire will discover if theres a bad wheel bearing, and the other method is good for discovering problems with steering components like bad tie rods,idler arm etc.. and a couple other important things would be to check strut mounts for damage, make sure both caliper bolts are in place and also uneven tire wear. it might not be the best way to diagnose problems but its worked for me, so check it out let me know what u find
  4. #3
    Supporter sequoiasoon is on the right track. sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    42
    Posts
    1,226
    Liked
    2 times
    Images
    8
    Rep Power
    11
    My '03 Sequoia started doing that and it turned out that the sway bar end link had rusted and snapped. Many have had same issue on Tundra and Sequoia. I'm at 87K on mine and last tire change I saw that the shock mount bushings are pretty much shot also.
  5. #4
    Lurking Member cbmatt is on a distinguished road. cbmatt's Avatar
    Join Date
    Feb 2010
    Location
    Columbus
    Posts
    23
    Liked
    0 times
    Images
    3
    Rep Power
    3
    Check the sway bar link for that wheel. It rusted and broke on my 2000 tundra this summer, it made a clunk everytime i turned the wheel or went over a bump. its an easy to fix if you have the tools, I replaced mine for around $45
  6. #5
    Rookie Explore KY is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Louisville, KY
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    01 Sequoia would Kluck only under certain road conditions like brick road, man hole covers, and rocky terrain. Replaced rack and pinion bushings and the noise went away. Had the wheel the alignment and steering was much more responsive. Truck has over 175K miles far exceeding the life of the rubber bushings.
  7. #6
    Rookie 04TRDTundra is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Berwick Maine
    Age
    30
    Posts
    17
    Liked
    4 times
    Rep Power
    0
    Definetely a sway bar link or possibly the steering rack bushing on the passenger side. I've never seen ball joints go bad on these trucks but the sway bar links do rust out and break causing "clunk" noises.
  8. #7
    Rookie viall78 is on a distinguished road. viall78's Avatar
    Join Date
    Jul 2007
    Location
    Gilbert, AZ
    Posts
    6
    Liked
    0 times
    Images
    2
    Rep Power
    0
    Look under the DIY section of first gen. It has some pretty good articles on ball joints, sway bars, and steering bushings. Upgrades I want to do to make my truck drive like it did new.
  9. #8
    Junior Member toyotalover79 is on a distinguished road. toyotalover79's Avatar
    Join Date
    Feb 2012
    Location
    Homestead, Florida
    Posts
    216
    Liked
    19 times
    Rep Power
    1
    Get your bushings checked. I had something similar in mine. I have a 2006 SR5 dblcab that I swapped a gas saver for with my brother. Anyways, I noticed a couple things on the truck (got it with 90,351miles) so I decided to take it into a garage I personally know and sure enough it was a couple of bushings in the steering rack and sway bars that were simply done. A couple of bucks and labor later and I was driving smooth again. Find a reputable garage or someone auto handy that you trust and have'em look it over.
    Hoped this helped.
    DH
  10. #9
    Rookie herrin is on a distinguished road.
    Join Date
    Apr 2012
    Location
    herrin
    Posts
    7
    Liked
    1 times
    Rep Power
    0
    For ball joint seal inspection and lubrication
    interval, refer to PERIODIC MAINTENANCE,
    Section 0.
    A periodic front wheel bearing repack is not
    required. However, when major brake service is
    being performed, it is recommended that the front
    wheel bearings be cleaned and repacked with a
    lithium soap, EP grease.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
