Deist Limit Straps Installed (Wheelers)
+ Reply to Thread
Results 1 to 4 of 4
Thread: Deist Limit Straps Installed (Wheelers)
  1. #1
    mandzach mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach is a glorious beacon of light. mandzach's Avatar
    Join Date
    Aug 2003
    Location
    Las Vegas
    Posts
    1,275
    Liked
    0 times
    Rep Power
    162
    Default Deist Limit Straps Installed (Wheelers)
    Put the new Coils and limit straps on today - any questions ...ask away.
    pics in my photos - by the way -the truck sits perfectly level up front from one side to the other , gave exactly 2" of lift. it rides great
    -not to rough, corners much tighter , hits bumps with a passion now
    07' DC 4x4 TRD Tacoma - 11Pk Custom Deavers / 3* shims - TC UCA's - DR 2.5 CO's - DR RR Rear Shocks - Light Racing Jounce Stops F&R - 285/75 16 GY MT/R Kevlar - AllPro F Bumper, Slidders & IFS Skid - Warn M8000 w/3/8" Technora - Piaa 510 Fogs - Hella 4000FF w/55w HID - Icom 208H/SG7500A - Midland 1001Z/Little Wil - PAP112/SA315P - EGHST1P dust light - Blue Sea fuse blocks cab/eng bay - DH G31 PM-1 Platinum - OTRATTW switches - 20lb Co2.
    Need Tranny Mods?--> IPT Valvebody calibration IPT Transmissions
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    JAW
    JAW is offline
    Supporter JAW is on a distinguished road. JAW's Avatar
    Join Date
    Aug 2003
    Location
    Manitoba, Canada
    Posts
    63
    Liked
    0 times
    Rep Power
    10
    Default limit straps
    I just installed wheeler coils as well but did not go with the straps, but I am thinking about it. Are you saying that the straps actually hold the truck down to a 2" lift, that is, there is constant tension in the straps? If so, and I am not a expert by any means, does this mean that your suspension has zero downward play from the normal riding height ie: the spring and shock can only compress, but cannot extend? If so, is this a necessarily a bad thing?
  4. #3
    Join Date
    Aug 2003
    Location
    Las Vegas
    Posts
    1,275
    Liked
    0 times
    Rep Power
    162
    Thread Starter
    Quote Originally Posted by JAW
    you know i just did it yesterday and didnt think about that - you are right -im wrong -the straps cant possible be holding the springs in normal sitting position. i was not really thinking when i wrote the post but thanks for correcting me, i assumed they had held the lift to an exact 2" but i was wrong - it must be the coils are just perfect side note- the guy helping me used a digital mic. on the new coils and we put the larger diameter one on the drivers side -maybe this helped. thanks for the correction.
  5. #4
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    49 times
    Images
    22
    Rep Power
    34450
    the limit straps should be preventing the damper from bottoming out, not preventing the damper from extending beyond static ride height...if that's the case, make them a little longer--you want the strap to catch right before the damper tops out. also assume if these are the single-web deist straps you will have a 10% stretch factor by length.
    -sean
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
