I'm looking at a used '03 Limited TRD 4x4, pretty much every option but
the dealer doesn't know if it has the LSD .
I think it's a safe bet but I'd like to know for sure before I spend my $$$
THANKS
Look at the rear differential...you should see a white sticker on the "pumpkin" that says "LSD". I believe it's packaged with the TRD 4x4 option?
Seee-ya,
Jim.
__________________ Base: '02 Tundra SR5 Imperial Jade Mica 4WD w/ TRD Off-Road, EVP Convenience & Tow Packages, Oak Interior & Captains Chairs, 6 Speaker/6-Disk CD, VIP 3K, Chrome Wheel Locks, & Anti-lock Brakes with DRL Mods: K&N FIPK II, Ram Air Performance System (RAPS), Unichip, Ivan Stewart Flares and TRD Grille, 2" Cornfed Front Suspension Lift (How-To Guide), BFG A/T 265/75's, Hellwig Rear Anti-Sway Bar (How-To Guide), JBA Headers & 2" Highflow Y-Pipe, 2.5" Exhaust Cutout with QuickTime Performance Electric Cutout (QTEC), Flowmaster 50 Series™ Delta Flow® Performance Muffler with Dual 2.5" x 18" Chrome Tips, ASP Racing Underdrive Pulley, PPD Billet Goodies, Rhino Liner, Tinted-windows, etc. Planned: My Tundra is done for now. Next up: Build new 400ci for my '69 Pontiac Custom S
Seee-ya,
Jim.
Thanks, i'll check that out.
I assumed the TRD package made the LSD standard too but everything I've read shows the LSD as a stand alone option &
the TRD package has
OF Off Road Package
Includes P265/70R16 tires with 16" x 7" alloy wheels, color overfenders, front and rear contoured mudguards, off-road tuned suspension with Bilstein shock absorbers and fog lamps. INCLUDES LF. NOT AVAILABLE with ST.
I assumed the TRD package made the LSD standard too but everything I've read shows the LSD as a stand alone option & the TRD package as having bilstein shocks, BFG Tires, fender flairs & mud guards, that's it.
Hmmm...I have a '02 so perhaps things were different in '03? Do you have the Tundra brochure from the dealer? It should have a chart that covers all the options/packages for each model. I'll check my '02 brochure when I get home and follow-up...
Seee-ya,
Jim.
OK, thanks, I'm going to go look for that sticker tonight!
actually I've lost my '03 brochure but the TRD package info I've found is what I'm finding after searching the internet.
OK, I checked my '02 brochure and under Access Cab SR5 it shows the LSD as an option after it lists all the "Packages" (Extra Value Package, TRD Off-road Package, etc.) My '02 window sticker shows it as a $275 option. (It was added as an option originally in 2001.)
Hope this helps...
Seee-ya!
Jim.
Just get them to jack it up till the wheels are off the ground and give a wheel a spin. If both wheels turn the same direction you've got LSD. If they spin opposit directions it's an open diff.
The TRD offroad package does not include LSD...thats a different package as Jim said.
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
