This is a discussion thread titled "I want my tundra to handle like a lightning. Suggestions?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-04-2004, 02:51 PM
JeffD's Avatar
JeffD's Photo Albums
Last Online: 04-23-2007 11:02 AM
JeffD is on a distinguished road.
Default I want my tundra to handle like a lightning. Suggestions?
Ok, well obviously my 4x4 TRD tundra is never going to handle like a lightning - but with close to 200K on the stock suspension my girlfriend gets carsick when she rides with me. The truck never really stops bouncing and swaying. My brother has an '01 lightning. She doesn't get carsick when I drive her around in that even though I am always in the boost and flying around corners like you wouldn't think a truck possibly could.
I have a set of the early fox/fabtech performance coilovers in the garage, but I wore out the bushings in less than 6 months of driving. I liked the way they felt with add-a-leaf's in the rear, but I am not interested in replacing bushings everytime I rotate my tires.
I don't want to lift the truck again, I already gave away my 33's, but I would not mind buying coilovers and leaving them around stock height, or lower to have a good stiff ride.
I have Michelin cross-terrains, and I also realize that those tires are very soft ride wise, but I think most of my car-sickness inducing motion is from the suspension.
Has anyone found any shock/spring combination that truly keeps the truck under control? I drive a lot of hard miles. Mostly on the road, and the off-road miles I do now is just driving through sugar sand in orange groves which I can do with street tires. I imagine a rear sway bar would not hurt that too much.
What shock/spring combination would work to make this truck sportier on the street. These tires still have about 25K left in them, so I am not going to replace them until november-ish.
My other option is to park this truck and get a 3-4 year old maxima SE to drive as my daily driver, and use the tundra for orange groves, and large trailer towing. But, right now I drive the truck every single day and nothing evey breaks. I am worried that if I start to let it sit it will become less reliable for when I need to pull a car across country with it.
Any suggestions?
Old 04-04-2004, 03:22 PM
Genthar's Avatar
Genthar's Photo Albums
Last Online: 11-18-2008 05:40 PM
Genthar is on a distinguished road.
Originally Posted by JeffD
Ok, well obviously my 4x4 TRD tundra is never going to handle like a lightning - but with close to 200K on the stock suspension my girlfriend gets carsick when she rides with me. The truck never really stops bouncing and swaying....I imagine a rear sway bar would not hurt that too much...Any suggestions?
Well, if you're bouncing and swaying, your shocks are probably dead and gone. Replacing your shocks will help with the bouncing and swaying, and if you have 200K on the stock springs, replacing those probably wouldn't hurt either. The TRD's are what you had, you could go with the bilstein HD/TRD Red-blue shocks which are stiffer, but you might sacrifice a bit of the smooth ride. The rear sway-bar seems to be the ticket of choice for turning stability, and if you get some disconnects for it, you can unhook it for when you're off-road so you don't lose the axle articulation.
Wheeler's Offroad also offers some poly-bushings for the front sway, which people have said helps stiffen the front a bit as well.
Not sure if there are any sport coilovers for the Tundra yet, I have the TW-SAW's and they're excellent, but, you said you didn't want to lift again, and they work the best with some preload (i.e. lifting), though you could run them at stock height
Genthar
Old 04-04-2004, 03:57 PM
Rlockyer's Avatar
Dealer : Crown Toyota Scion
2004 Toyota RAV4
Rlockyer's Photo Albums
Rlockyer is on a distinguished road.
The Hellwig swaybar was the best $150 I ever spent on my truck.
Corners better than a Silverado now.
There's nothing wrong with the cross terrains, just run them at 35psi.
2003 SR5 TRD V8
Traded in, 8-20-2005 with 125k trouble-free.
Old 04-04-2004, 04:18 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: Yesterday 11:03 PM
SATundra is on a distinguished road.
Ditto, I agree completely with Genthar.
Heres the link to Wheelers for the shocks and springs: Wheelers Off Road - TRD stuff
Heres the link to Hellwig for the swaybar: Hellwig swaybar
Heres the link to Wheelers for the front bushings: Wheelers bushing kit
I have a 2WD and added the 4x4 red/blue Bilsteins and 4x4 TRD springs to the front, also added the yellow/blue 4x4 Bilsteins, Hellwig swaybar and TRD add-a-leafs to the rear. The truck handles like a dream. No dipping, swaying or leaning at all. You can take corners like a sportscar AND hail around loads with this setup.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 04-04-2004, 04:52 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Verndog's Photo Albums
Last Online: 10-29-2008 07:37 PM
Verndog is on a distinguished road.
but with close to 200K on the stock suspension my girlfriend gets carsick when she rides with me. The truck never really stops bouncing and swaying. Any suggestions?
Well, I'd say the cheapest thing to do is throw her in the back.
If she doesn't go for that, one great mod is the Wheelers leveling coil overs, it tightens up the front but still rides nice, and bonus, levels the truck!
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 04-04-2004, 07:44 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
TRDKEAU's Photo Albums
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
new shocks (mild to wild itill make a difference)
coilovers will I think be softer if left lower, you can set a little less than 1.75 and be firm.
rears and leaf packs
sway bar (helwig=cheap and effective. hotchkis=$$ but will have a front and rear setup)
New bushings great buy, load those polys up with lube so theres no squeak!
Drive a little better.
Old 04-04-2004, 08:17 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
keiphers's Photo Albums
Last Online: 11-27-2007 02:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers
Hotchkis has an anti-sway bar kit for our trucks?
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 04-04-2004, 09:05 PM
03TundraTRD's Avatar
03TundraTRD's Photo Albums
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
Check the Thread "Lowering Trucks Check in" above and there is a sportcoilover system coming out soon it will drop the front end bout 2''. I also have the Hellwig anti-sway bar it REALLY helps in cornering.
Old 04-04-2004, 10:38 PM
TRDKEAU's Avatar
2006 Toyota 4Runner
http://www.hotchkistuning.com/cgi-bi...oyota%3BTundra
Still about 90 days out, but on its way, theres another application for the front and rear made by addico in florida. But they will not fit 02 and below
Old 04-04-2004, 11:16 PM
JeffD's Avatar
Thanks guys!!! I am always driving the truck a bit rough, but when she is with me I try to be very smooth. The truck still just kind of wallows. The other thing is that all the roads here are under construction, and instead of just dropping when the pavement drops, the truck kind of rocks front to back a couple times.
I guess I will probably go for the rear sway bar, and check with hotchkiss to see if there is a front one available bigger than stock. I had done the poly bushings before, but took them out because I could not keep them from squeeking for very long. I thought maybe it was because I had greased them.
I will probably also try the red/blue HD bilsteins. If they don't work wonderfully I won't be out much cash.
Old 04-07-2004, 06:51 PM
chrislloyd's Photo Albums
Last Online: 05-29-2008 06:44 PM
chrislloyd is on a distinguished road.
i had 50someK miles on my tundra.... it also bounced and leaned far far more than new. i have a TRD model. it was nice in the beginning... but quickly faded. i just added the fabtech coilovers, fabtech rear shocks and add a leafs. before i adjusted the fronts up, i was SOOO impressed with the ride. i drive the same way to work everyday. therre are 4 speed bumps. i went right for those after the installation. i tried them slow and fast. it was AMAZING how much better the truck felt. after adjusting the front upwards... it still handled great. the speed bumps were a bit more harsh, but far better than the factory setup.
the first offroad trip was truly amazing. the things handled better that i could have imagined. it is more fun to drive now that ever before. if i do get a new DC, the first thing it will get is new suspension.
Old 04-08-2004, 10:16 AM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 12:34 AM
jeff-
with 200K on the truck, new shocks & springs and you'll probably be just fine. the stock rear springs are very floppy to begin with...you regularly tow/haul? theyre probably getting pretty bad. if you plan on keeping the truck for a long time, look at alcan, deaver, and nwor rear spring packs. if you're going to sell it soon, just get an add-a-leaf to pass the time.
there is nothing wrong with your front swaybar. seriously...it's just fine. try better shocks and some new springs--see if you can get a set of take-offs from someone with a new truck who recently bought coilovers, and put 'em on new shocks.
the rear swaybar is a must . one of these days, i'll put mine on .
-s
GFX by FreedomEagle50
Manual Hubs
Old 04-08-2004, 06:17 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
v8Toilet's Photo Albums
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
200k on original shocks, man you need new one! The shocks job is to control spring oscillations (bounce). This should be your first modification.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Dyno run 2 results click here
Old 04-17-2004, 10:37 AM
JeffD's Avatar
Ok, so I am going to get the rear sway bar, Bilstein HD shocks for the rear, and some springs/shocks for the front. I have a new set of oem/TRD rear springs here already. where they came from is a long story.
Now my question is. If I am going to buy Bilstein HD front shocks, and TRD front springs from wheelers, and rent the spring compressor - would it be better to buy the bilstein coilovers and run at stock height. If that is better, would running the SAW's, or Donahoe coilovers at stock height be even better.
My definition of better would be a stiffer, more controlled ride on the street with less swaying. I am sure that all of these options would prevent the topping/bottoming problems I have in the dirt.
So I would be looking at $500 for the front using Bilstein HD's, and OEM Springs, to a max of $1000 for donahoe coilovers.
Do you need to run Limit Straps with the Bilstein Coilovers?
It's hard to justify spending over $1000 for shocks/springs/swaybar when the truck already has so many miles on it and may die at any time. On the other hand it still looks and runs like new, and I still drive it a thousand miles a week average. I spend almost that much on tires and brakes every so many miles. I spent a bunch of money on the Fabtech/P setup - any of this stuff would surely work better than that. I still enjoy driving it and have been considering putting the S/C on it. And I only have to justify it to myself.
I would say the front springs are worn out. Before Cornfed came here on the site I machined myself a set of spacers for the front springs, except I put them between the top of the spring, and the spring seat. basically adding a bunch of preload to the stock spring. Not realizing exactly what the ratio was, I made the first set 2" high. Once I managed to get the springs/shock back together, the truck rode totally topped out. I realized what was wrong, and cut them down to about 1 inch. That worked well, I ran them like that for a bunch of miles. Having taken the spacers out, the truck now sits lower in the front than anyone elses tundra that I know of. So I am pretty sure I need to replace them.
Old 04-17-2004, 12:02 PM
tundrabrad's Avatar
Inactive Account
Dealer : Bill Wright Toyota Scion
2003 Toyota Tundra
tundrabrad's Photo Albums
Last Online: 10-29-2005 01:45 AM
tundrabrad is on a distinguished road.
Send a message via AIM to tundrabrad
Buy an MR2 if you want something that handles and can make your girlfriend really sick!
Brad
