Power Steering Problem/anyone Else?
+ Reply to Thread
Results 1 to 7 of 7
Thread: Power Steering Problem/anyone Else?
  1. #1
    Rookie RETLEP is on a distinguished road. RETLEP's Avatar
    Join Date
    Jul 2002
    Location
    CT
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Unhappy Power Steering Problem/anyone Else?
    I have 25k on my 02 4wd ext.cab TRD. In the last couple of
    months my steering as been feeling "different". It almost feels like its stiffened up or the p/s assist has dropped.
    At first I thought I was just imagining things but now it drives me crazy! When I drive over dips in the road I feel the steering pull to the left or right. I don't recall this happening before. Bad shock or bad rack? Anyone else have any similar problems or suggestions?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    47 times
    Images
    22
    Rep Power
    34450
    the pull over dips thing makes me think alignment...dj would know best.
    -s
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  4. #3
    KLS
    KLS is offline
    Supercharged Member KLS is on the right track. KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,520
    Liked
    1 times
    Rep Power
    15
    The rack must stay tight. If you're still under the 3/36 warranty, have the dealership fix it. If you're out of the warranty, have the dealership or a good front end shop do the job.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  5. #4
    DJ
    DJ is offline
    Supporter DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points.
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,013
    Liked
    171 times
    Rep Power
    8592
    Quote Originally Posted by RETLEP
    It's called "bump steer". The likely cause is a steering rack that has shifted to one side. The problem is with the mounting of the rack coming loose.
  6. #5
    Join Date
    Jul 2002
    Location
    CT
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thumbs up loose p/s rack!
    Thanks, DevinSixtySeven,agbayani50,KLS,& DJ for your suggestions!
    It's amazing how much more helpful Tundra Solutions is than your average Toyota dealership service writer is- ie:
    "never heard of it".
    Is this loose rack fairly common? I do not take it out 4wheelin. Just New England potholes...
  7. #6
    Veteran Member mitchr is on a distinguished road. mitchr's Avatar
    Join Date
    Feb 2002
    Location
    Kingsport, TN
    Posts
    640
    Liked
    0 times
    Rep Power
    12
    Since they done the "major front brake TSB" on my truck I have noticed a rattle in the right front. Does anyone know if the rack could be affected or worked on during that tsb.
    Thanks, Mitch
  8. #7
    Supporter dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs is a splendid one to behold. dsconstructs's Avatar
    Join Date
    Apr 2003
    Location
    Fairfield, CA
    Posts
    705
    Liked
    0 times
    Rep Power
    20
    Quote Originally Posted by mitchr
    Thanks, Mitch
    The rattle may be the inside brake pads. Try reversing slow and tapping the brake and see if that is the sound. I know it is on mine, it rattles over some bumps while driving but works just fine.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
