Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 05-18-2004, 10:45 PM
Last Online: 06-24-2005 08:36 AM
Evel is on a distinguished road.
Evel's Photo Albums
Default Shocks and front springs
Hi All,
I believe I have a blown right front shock. Truck is a 2001 4x4 access cab limited with TRD off road package. When hitting bumps the right front bottoms and also rebounds bad.. The left side seems fine.. My question is: Should I buy the Wheeler front springs along with new HD Bilsteins front and back.. I don't care to lift the back anymore than stock but IMO the front end sits too low in stock trim. The special Wheeler front springs are supposed to level the truck..
Anyone out there gone this route..
Thanks,
Evel
Truck has 70k miles
Old 05-18-2004, 11:00 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
You may have blown a shock or worse. Get it checked out.
At 70K, your shocks and springs are pretty weak. Wheelers coils are great and they do lift the front about 2.5". On the down side they are stiff and you will spew grease from your CV boots. (hose clamp mod will cure this)
Another option would be TRD 4WD coils. These will lift the front a bit, give a smooth ride and not effect your CV boots.
I had Wheelers, sold them and went back to OEM coils with HD Bilsteins. These ride great, maybe a little soft. I just aquired a set of TRD coils.
Good luck
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 05-18-2004, 11:05 PM
Evel's Photo Albums
Thanks that was the answer I wanted. BTW I HAVE TRD coils in my truck from the factory.. At least I thought that's what I paid for when I got the TRD off-road package?
Cheers,
Evel
Good luck
Old 05-19-2004, 01:19 AM
Evel's Photo Albums
I will be the one checking it out.. I have never let a dealer touch any vehicle I have ever owned except for warrenty work and they usually F_ck that up
Cheers,
Evel
Old 05-19-2004, 09:10 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
easy to check, just bounce each side of the truck. the good side shouldnt bounce, the bad side will.
the trd shocks & springs that come with the truck (unless you have an IS edition) are fairly soft, they provide a very comfortable car-like ride and flex well offroad, though the stock setup doesnt have much uptravel. wheeler's coils are stiffer, great if you have a brush guard, winch bumper, or brush guard/winch combo.
-sean
GFX by FreedomEagle50
Manual Hubs
