Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 05-22-2004, 02:12 PM
Last Online: 10-28-2007 08:15 PM
mkeef is on a distinguished road.
mkeef's Photo Albums
Default Level 00 Tundra
What is the best way to level a '00 Tundra. I have heard a few options. A friend told me to get longer springs. I also saw a leveling kit that are just spacers. Then I when to ORW and the guy there said that they had problems with how the leveling kits ride, so he suggested set of adjustable coilovers. He said it would give the front end a 2-4 inchs and you can adjust to how you like it. I only need 2inchs, any more than that and the front will be higher than the bed...
Any Suggestions
Old 05-22-2004, 02:47 PM
GaryFisher's Avatar
Dealer : Herb Chambers Toyota of Auburn
Last Online: 02-06-2009 11:36 AM
GaryFisher is on a distinguished road.
Send a message via AIM to GaryFisher GaryFisher's Photo Albums
Cornfed suspension spacers. Easy mod dont cost too much in terms of suspension and level the truc kout nicely.
SR5 V6 4X4 5Spd Modifications Include... ACT performance clutch, Bassani Split Side Duals, Fabtech Shocks and front Coilovers, IS Kit, Grillecraft Grille, BBS Wheels, 285/75/16 Firestone Destination M/T's for wheelin, 20" Enkei RT-6's w 295/50/20's for street , Air Box Mod, Pro Comp Boost GaugeTRD Supercharger, URD Fuel kit, URD 2.2 Pulley ALL GONE - Now Audi S4 Avant
Old 05-22-2004, 03:55 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
It depends on what you want to do. If you just want to level for show, use the spacers. They're cheaper. If you want to level and lift for possible offroading, go with an adjustable coilover for better performance.
Either one will firm up your ride, though a coilover is more adjustable.
If you're running a 4x4, be aware that lifting the front will cause your CV boots to leak.
Genthar
Old 05-22-2004, 03:57 PM
emstro's Avatar
Dealer : Stadium Toyota Scion
2003 Toyota Tundra
Last Online: 02-10-2007 02:01 PM
emstro is on a distinguished road.
Send a message via AIM to emstro emstro's Photo Albums
Don't do it if you trailer anything. It'll ride funky.
2003 V6 SR5 Tundra
Motion Designer
Old 05-22-2004, 06:26 PM
Tundy's Avatar
Dealer : Hanlees Hilltop Toyota Scion
Last Online: 12-08-2006 11:45 PM
Tundy is on a distinguished road.
Send a message via AIM to Tundy Tundy's Photo Albums
How hard is it to install the Cornfed spacers by yourself? What is the process?
Thanks
Old 05-22-2004, 09:23 PM
My tundra is a 2wd. I don't do any off roading. If and when I get into that, I'll get a 4x4. I just don't like the stock look with the lower front end, so its just for show. I was thinking the spacers were the way to go until the guy at ORW told me that they had problems with the way they ride. The ads for the spacers that I have seen say they keep the stock ride. So I was looking for a unbiased opinion...
Thanks...
Old 05-22-2004, 09:29 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Thanks...
Try and find a set of new/take off TRD coils.
The TRD coils alone may give you the look you want.
If that doesn't give you enough lift a set of HD Bilsteins in the front will bumped it up another 1" or so.
I would stay away from spacers.
Do you have a V6 or V8?
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 05-22-2004, 10:13 PM
I need about 2 inches, do you think the TRD coils will give me that?
V8...SR5 Access cab...
Old 05-22-2004, 10:59 PM
H2O_MAN's Avatar
I don't think the TRD coils alone with lift the V8 2".
HD Bilsteins and the coils should work.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
