On a stock rim, you can go w/ a 265/75R16 and you do not need a lift. Some have put on 285/75/R16 on a stock rim, but it is not recommended by the tire manufacturer (The tire's sidewalls buldge too much.) you should have a rim that is at least 7.5" wide (stock is only 7"). A 2"-3" lift is all you should need for the 285's to fit. For spacers there are Cornfeds. For coil-overs, there are the Team West SAW's (TS Member), Bilsteins (from Off-Road Warehouse) or you can go with the coils (from Wheeler's).
'01 Color-Keyed Limited Tundra TRD 4x4
JBA Headers, TRD Exhaust, IS Grill, IS Bilsteins, Hellwig Sway Bar, AR-23 wheels w/ 265/75 Yokohama AT's, SnugTop XV Shell, BedRug, Yakima Rack
