Questions about Lift
+ Reply to Thread
Results 1 to 2 of 2
Thread: Questions about Lift
  1. #1
    Rookie TONYJETT is on a distinguished road. TONYJETT's Avatar
    Join Date
    Dec 2003
    Location
    LONG ISLAND NY
    Age
    75
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Question Question about Lift
    HI ALL,
    I am a new member bought my Tundra Oct 1999 from Millenium have
    28,000 miles on it and recently installed the TUFF Country spacers...
    the installation went very smoothly, and shortly thereafter I had grease
    leak from both inner CV Boots, the boots are like new not cut etc & the
    leak is from under the large band that clamps the boot...the clamps are
    tight ( cant move them by hand ).
    The lift levels the front very nicely with a full 2" lift ( I measured before &
    after) and also improves the cornering...and the ride is not that much
    harder.
    I put this post on the IATN network ( I am a ASE Certified Master Auto Tech
    10 years ) ( currently working as a NYS reg Pharmacist) and got 3 replies
    2 had the same experience and said not to worry, one stated the angle
    was too severe and to do the Fabtech Lift.
    I was wondering if any of you out there had a similar experience...I guess I
    am looking for reassurance...
    I cleaned up the area & put a bead of black RTV on the leak area , so far
    it appears to have stopped.
    I also did the Hellwig rear sway bar...very smooth installation and the vehicle
    handling is greatly improved....I noticed on the 2004 Tundras the rear sway
    bar is standard.
    Thanks in advance for your comments
    Tony
    I SOLVED THE PROBLEM IN JUNE by cleaning out the old grease and pumping
    in about 8 pumps of chassis grease ( the CV boot lubricant was too thin
    & would leak) have gone over 4000 miles with no problem.
    Last edited by TONYJETT; 10-05-2004 at 08:33 AM. Reason: CHANGE TO HANDLING & SUSPENSION FORUM
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally's Avatar
    Join Date
    May 2001
    Location
    Over Yonder
    Posts
    955
    Liked
    2 times
    Rep Power
    1070
    Hi Tony!
    Welcome to Tundra Solutions! I see you already picked up a club membership, so check out the Club Garage Forums, and you should find answers to most, if not all, of your questions!
    ~MS
    ~~MustangSally~~
    2001 Tundra Limited
    TRD 4x4
    Imperial Jade Mica/Thunder Gray Metallic
Posting Permissions
  • You may not post replies
  • You may not edit your posts
