This is a discussion thread titled "just talked to total chaos re: heim steering conversion", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-24-2004, 01:38 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 11:27 AM
Default just talked to total chaos re: heim steering conversion
i heard a rumor they were working on something like this, so i called 'em...theyre not working on something like this for the tundra until the taco kit is ready, and the taco conversion is for the LT kit.
i was specifically asking about a heim conversion for a stock-width tundra, in effect a sturdier steering setup for a "mid travel" tundra, as the weak links are the upside down lower ball joint (and small, on the 00-02) and the tie rod end.
dunno if anyone would be interested in this as well, perhaps interested enough to look in to a conversion for the lower ball joint to a uniball similar to the upper ball joint, where the pivot point is relocated to the lower control arm rather than the steering knuckle. this would take some welding, machining and fabrication skill and resources, but with a sturdy lbj and tre joint, i think an ifs tundra could take most of the abuse we can dish out. the drivetrain will still be small in front, but the suspension joints will be less likely to fail.
if this is possible, it'll keep me from wanting/needing to go the sas route, at least for a while longer.
would anyone be interested in a heim steering conversion, either for LT or MT setups? how about a lower uniball conversion of some sort--i dont see the same sort of market as with the upper, as there's a lot more work involved and probably less interest, it would just be stronger and as with the upper uniball conversion, easier to r&r and so forth.
the heim conversion t/c is working on DOES NOT change the pivot point and hence DOES NOT CAUSE BUMP STEER. i did not ask if the conversion was single or double shear, it sounded like single tho, i think double shear would only be possible with a new steering knuckle. i wish i had an end mill or better yet a cnc end mill .
-sean
GFX by FreedomEagle50
Manual Hubs
Old 08-24-2004, 02:46 PM
tpgn00's Avatar
Dealer : Burt Toyota
2008 Toyota Tundra Silver SR5 DC
tpgn00's Photo Albums
Last Online: Yesterday 12:05 PM
tpgn00 is on a distinguished road.
Send a message via AIM to tpgn00
Just a thought but what about a better spindle. I read a while ago about a member on the desert rides website that broke the stock spindle in his tundra. How stout is the factory spindle?
- Kees -
Handling, Suspension & Brake Discussions Moderator
MODS: : line-x, camburg coilovers, tint, 305 65 18 BF Goodrich All-Terrains, sirius
Father to Jack: Born 1/16/08 2lbs 11 oz.
About to post a question? Try Searching the forums first!
Muay Thai Kickboxing of Colorado
Old 08-24-2004, 02:52 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
keiphers's Photo Albums
Last Online: 11-27-2007 01:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers
Wasn't some shop going to make a beefy 3" lift spindle? That'd have been sweet.
But, to the point of the thread, I'm interested in both. I know I won't be going LT or SAS in the near future, so I want to make the most out of my MT.
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 08-24-2004, 04:13 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
TRDKEAU's Photo Albums
Last Online: 07-24-2008 11:36 AM
TRDKEAU is on a distinguished road.
That guy had camburg LT with 35" projects slapped on some Heavy Walker Evans beadlocks. A stout spindle is bucks, gussets would help as well as extending the bumpstops.
Old 08-24-2004, 05:43 PM
flyin6 modded his spindles, there's another member here with a custom ifs drop bracket on a 4x2 with modded spindles, iirc bill west has also done this sort of mod in the past tho i dunno if it's been done to his tundra.
anyway, from what i hear it helps quite a bit, and i will be doing that inconjunction with heim steering and anything else (within reason) i can to further stave off the need for a solid axle, as i havent the time or resources to start that project yet.
-sean
Manual Hubs
Old 08-25-2004, 06:00 PM
Lalo's Avatar
TEAM SCT
Dealer : Kearny Mesa Toyota Scion
2000 Toyota Tundra,
- Other - 1998 VW PASSAT 1.8T
Lalo's Photo Albums
Last Online: 04-28-2008 02:51 PM
Lalo is on a distinguished road.
Send a message via AIM to Lalo
I was just getting quotes on this from Wicked Motorsports in Orange County, they can do it, but it would be expensive. either way it would be a great mod for those who need it.
www.SoCalTundras.com
Old 08-25-2004, 06:52 PM
keiphers's Avatar
True. Seeing as there is no one that I know of / trust on the east coast to beef up my spindles, I'd probably buy new beefier ones with lift before I modded my current ones. Cali is too far to send my spindles. Plus, I've had way too much downtime on the truck lately.
2003.5 BMW M3
Old 08-26-2004, 05:46 PM
keiphers's Avatar
Any more news?
2003.5 BMW M3
Old 08-30-2004, 06:37 PM
Lalo's Avatar
TEAM SCT
2000 Toyota Tundra,
Lalo's Photo Albums
I'm interested in Heim steering if anyone gets the ball rolling...
Old 08-30-2004, 06:57 PM
TRDKEAU's Avatar
2006 Toyota 4Runner
A truck is being prototyped as we speak. A friend of the family you might say.
Old 08-30-2004, 07:12 PM
Lalo's Avatar
TEAM SCT
2000 Toyota Tundra,
Lalo's Photo Albums
sweet. Total Chaos sure is stepping up to the plate when it comes to Tundra aftermarket...They need a TundraSolutions award!
Old 08-30-2004, 08:01 PM
keiphers's Avatar
Read on ...
Originally Posted by Total Chaos email
Keith,
Thanks for your inquiry with TOTAL CHAOS. The Tacoma upgrade was completed last week and the machinest will begin the Tundra LT version in the next week or so. Your request for stock length might be an option. We were only going to offer the long travel version. I will discuss this possibility with the design department and contact you via e-mail next week regarding a stock length replacement heim steering upgrade.
Nicole Pitell
Marketing Director
TOTAL CHAOS Fabrication
159 North Maple St. Unit J
Corona, CA 92880
909-737-9682 p.
909-737-9006 f.
www.chaosfab.com
2003.5 BMW M3
