Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 09-29-2004, 03:32 PM
Last Online: 10-05-2004 08:32 AM
ufga025 is on a distinguished road.
ufga025's Photo Albums
Default help me choose
old and played out im sure, but im looking to get some things in bulk for my tundra.
i want a 3" suspension lift kit (that will come with everything i need)
16 and or 17 inch rims with 33" tires
headers im gonna go with JBA and muffler most likely a spintech. but which y pipe should i use and which cats should i use. also what series spintech do you guys use on your truck (for those that have them)
also looking at the TRD lsd how much did u guys pay for yours and where did you get it from.
everything else as far as cosmetics and skid plates and bumpers i have figured out. but i have the money and need to know what to spend it on. anyhelp is greatly appreciated
Old 09-29-2004, 06:04 PM
greener's Avatar
Dealer : Toyota of Des Moines
2003 Toyota Tundra
Last Online: 05-09-2009 04:18 PM
greener is on a distinguished road.
greener's Photo Albums
I've been trying to figure out the best lift solution for the last month or so. I'm probably gonna go with a set of adjustable coilovers, more than likely King.
Down the road, I'll prbably get a pair of Total Chaos arms.
When I get some more money saved up, I'll lift the rear and crank the coilovers up another 1" or so.
Old 09-30-2004, 12:48 AM
icarusarna's Avatar
2003 Toyota Tundra
Last Online: 09-03-2009 08:47 PM
icarusarna is on a distinguished road.
icarusarna's Photo Albums
Well Im planning on getting some Teamwest Coilovers for my Tundra and recommend that you also get Upper Control Arms (Camburg or Total Chaos).
I have a Spintech muffler and its the Sportsman XL. I suggest that you keep the stock pipe sizing like everyone else says. I have slightly larger piping and I can feel the lost of low end torque. Y pipe i dunno, just leave it stock i guess, you dont really want to mess with that. LSD, i purchase mine from another TS member awhile back for like $250.00 and got it install for $300.00. So yeah hopefully i answer your questions.
Old 10-01-2004, 09:11 AM
thanks for the help guys, keep it coming id like to get a mix of ideas on power and suspesion set ups. plus appearance and wheels/tire combo.
Old 10-01-2004, 04:41 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
suspension=
- adj. coilovers <teamwest is an excellent choice, allows you to customize a shock to whatever spec you want and is affordable>
-TC upper a arms < gives you 1" more droop than stock and replaces the factory ball joints that are vulnerable to stress>
-didnt say if youre a 2wd or 4wd. 4wd I would recommend diff drops by total chaos, and HD cv clamps. if your boots rip, theres a member who has sourced out 930 boots that are cheap. labor on those are anywhere from 80-300, good 4wd store will do them cheaper.
-Rear springs, deaver leaf pack. Teamwest also has these custom made to an 11 pack spec. the spring rate is progressive and the rear feels nailed to the ground. gives you an extra 2 inches of lift.
-rear shocks go with either a bilstein 5100 or 7100, these are short of cutting through the bed.
- wheels and tires: this is personal preference, I myself if I could do it all over again would go with the walker evans 17" simulock or real beadlock rims. www.walkerevansracing.com , tires depends on how much your on/off road BFG all terrains are good for everything. Goodyear MTR's if you do alot of trail, muddin such and such.
PM me for more details and sourcing out parts if you need a hand
Old 10-04-2004, 09:30 AM
excellent info. thanks for everything, ill pm you if i need some nitty gritty stuff, but thats the just of it i guess. oh and the truck is 4wd, and most of my time is onroad but i DO some off road on weekends...
Old 10-04-2004, 10:53 AM
dbldutch's Avatar
Mod formerly known as tpgn00
Dealer : Burt Toyota
2008 Toyota Tundra Silver SR5 DC
Last Online: Yesterday 11:52 PM
Images: 6
dbldutch is on a distinguished road.
Send a message via AIM to dbldutch dbldutch's Photo Albums
I have a 4wd and i have the donahoe coilovers with the total chaos diff spacers as well as the Team Gordon wheels. I haven't had a chance to do anything to the rear but you can check my pics to see how it looks.
- Kees -
Handling, Suspension & Brake Discussions Moderator
MODS: : line-x, camburg coilovers, tint, 305 65 18 BF Goodrich All-Terrains, sirius
Father to Jack: Born 1/16/08 2lbs 11 oz.
About to post a question? Try Searching the forums first!
Muay Thai Kickboxing of Colorado
