Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 10-02-2004, 07:09 AM
gnb gnb is offline
2002 Toyota Sequoia
Last Online: 10-05-2009 04:47 PM
gnb is on a distinguished road.
gnb's Photo Albums
Default 2002 Sequoia @WD- Best Replacement Shock Options
Our 2002 SR5 Sequoia 2 WD is at about 34K miles and it seems (?) that the suspension has gotten a little softer.
Perhaps the original shocks are getting tired from holding up the 5,000 ofr so pounds the Sequoia weighs.
What is the the best shock for the Sequoia that will provide a firm, but not uncomfortable ride ? Perhaps a bit firmer than oem but not too firm ( comfortably firm).
It's my wife's daily driver so it has to absorb speedbumps and potholes without being "bone jaring".
Seems a lot of people here like the Bilsteins.
Thanks, GNB
Old 10-06-2004, 12:05 AM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Originally Posted by agbayani50
BE5-6024 Fronts same as Tundra $75.00 each
BE5-6738 Rears $60.00 each
Call OffRoadWarehouse 800-341-7757
Much appreciated !!
As a DIY project the rear shocks look to be straightforward.
How about the front shocks - what's involved in replacing them ?
Old 10-06-2004, 12:11 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I have spring compressors and I'm used to using them, so I found the rears to be more trouble than the fronts on my Tundra. The fronts took longer, but the top nut on the rears is in a tight location.
You do need the spring compressor, and you need to know how to use it. If you do it wrong, you could remodel your face. Rent some spring compressors and get instructions. Be sure to put the spring back into the pocket in the spring seat. Note the orientation of the studs on the top before you disassemble it and put it back together exactly the same way.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-06-2004, 08:00 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Sure the rears aren't BE5-6025's ??
If not, why not ?
Old 10-07-2004, 07:55 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
The BE5-6025-H0 are made for the TUNDRA. The Sequoia Rear is much heavier than the Tundra. And plus, the BE5-6738-H0 is what Bilstein has in their catalogs.
BTW, Some advertisers POST, "FREE SHIPPING & NO HANDLING CHARGES" ORW is by far has the cheapest pricing even with shipping inc. 800-341-7757
Thanks for clearing the rear shock model numbers !
BTW- how is the ride with these Bilsteins versus the oem shocks that came on my SR5 Sequoia ?
Also- does 35 K miles sound right for the oem shocks to begin getting softer?
Thanks
GNB
Old 10-08-2004, 02:12 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Much appreciated !
I also prefer a stiffer ride on the cars & trucks I drive .
My wife drives the Sequoia- Do you think she would find the Bilsteins too stiff? The Sequoia has from the factory a somewhat of a "car like" ride ( soft) to it.
GNB
