Just got 2 1/4" of lift with Wheelers Coils. I also added the 1" diff drop spacer kit. Can I add an extra 1" spacer to lift it even more without any Ball Joint issues ???? I couldn't seem to find an answer through the search function if the 1" drop allowed a little more lift to be put in.
Thanks
Tom B.
2007 - DC TRD 4x4, Slate, 5.7 SR5, Toy-Tech 3", 285/75/18 Toyo's Open Country AT , Bedrug, Truxedo Tonneau, N-Fab Nerfs, Eclipse NAV, MB Quart, RFosgate, etc., Snow-Way, TRD Sway Bar
1971 Chevy Monte Carlo Street/Strip - 10.31 @ 130
1970 Chevelle 454 LS6 Power
1987 Olds 442 - Stock Racing Web Page
Once you start lifting, your stock parts will start to wear more excessively. Going more than 2.5" will be too extreme. To help out you can upgrade to the TC uni's and not have to worry about ball joint boots and the such. Also, consider changing out your rubber bushings with poly bushings. Another item from TC is the rod ends, consider those once they are available.
The diff drop spacer helped out on the CV angles but not the ball joints.
Change to new UCA's such as the Chaos and then lets say I add a 1/2" spacer...Does anyone make one a 1/2" spacer ???
Mike, I understand about the CV joints and the diff spacers, I have heard some say 2 to 2 1/2" is Ok without the diff spacer so one would think adding another 1" would still be OK for the CV Joints when you add the diff spacer. Probably doesn't quite work that way. Anyone drop the diff 1 1/2" to 2". Haven't researched that at all....just asking.
Thanks again for the info..
Tom B.
do you really get 2.5" of lift out of the wheeler's coils? is that measured before and after from the hub to fender?
another company to consider in the UCA area is Camburg. They're about $150 cheaper...but they're "not as beefy"...the Total Chaos may be overkill on a street driven tundra though.
definately get the UCA's before you try to go any higher.
2 1/4" Exactly..measured from Hub to wheel opening both sides and from ground to frame. The best part is that these were slightly used and should be "settled" already.
So if I get new UCA's I could add another 1", concerned about the CV Joints though..
Tom B.
Before I installed my UCAs, the boots around the stock bolts were spewing greese... definitely didn't look good. This was simply with Wheeler's coils... no extra spacer. I'd highly suggest just going with new UCAs from the start.
Ha! Let's just put it this way... I'd feel acomplished if I DID break my Camburg UCAs!
Armada 176 AR5s Skis, Look P12 Jib Bindings, Rossignol Bandit B1 Boots, Scott Poles... in the bed of a 2000 V8 Tundra 2x4 Access Cab with:
JBA Titanium Coated Headers, Stone Mountain Racing Y-Pipe, Flowmaster 50 Exhuast, Teamwest Sway-A-Way Coilovers, Camburg Upper Control Arms, Wheeler's Add-A-Leafs, AEM Brute Force Intake, MB Quarts, US Acoustics Amp, Bazooka Tube, Lots of Dynamat, A.R.E. LSII Tonneau Cover, Sir Michaels Rollpan, Bushwacker Flares, Shaved BSM, Billet Grilles, Mickey Thompson Classic Locks, 305/70/16 Pro-Comp X-Terrains, Lots of little things here and there. Future Projects: Color-Coded White Rear Bumper and Tailgate handle, Revalve SAWs, Deaver 11 Leaf Packs, Bilstein 5100 Rear Shocks.
All this info repeated here!
