Originally Posted by johnakers
I have an 01 v8 Access Cab and just ordered PowerSlot Rotors and Hawk HPS Street Pads. I found a Howto on replacing pads but what about the rotors? Anything I should be aware of when doing this job? Is it necessary to bleed the brakes? I have d/l'd an article on "bedding-in" the brakes from Street performance so I assume that is the best method.
Looking at the head of the bolt, turn counterclockwise to remove. I don't know about the 01 Taco, but on my 98 4R the caliper is piped with metal hydraulic lines. If your is, carefully bend the line as little as possible so as not to pinch or break it. It helps to have a preformed wire ready to hang the caliper on. At this point the rotor should just slide off.
You will have to squeeze the pistons back into the calipers in order for the pads to clear the rotor, compensating for wear on the old parts. This backpressure may very well cause your master cylinder to overflow, so you might want to draw some brake fluid out of it and put a catch pan under it. Whatever you do - don't let any crap fall in there.
A c-clamp can be used to squeeze the pistons. When they are in, install the shims, pads etc. and slide the calipers over the rotors, again being careful of the brake lines. Tighten everything up with a torque wrench, including the lug nuts. Then check the fluid level in the master cylinder. As long as you haven't opened a brake line somewhere there is no need to bleed.
As for 'bedding' the brakes - car manufacturers have break-in periods where you are supposed to drive gently and avoid hard stops. It's possible to warp your rotors by overheating them (the amount of friction they generate is significant) and cooling them too fast or by holding the brakes 'on' a stopped, hot rotor (since the cooling rate under the pads is different than the cooling rate in the air). Splashing water on a hot rotor is a common cause of rotor warping. I bed new brakes the same way I break in a new car, driving moderately. It achieves the same effect with less wear and stress on the vehicle.
Read
this page at
tire rack (search for 'bed' on page) to see how others fared with your pads. Pay attention to how they took up to 500 miles to bed or 'brake' in.
