This is a discussion thread titled "Full Float Axle Conversion", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-31-2005, 11:47 PM
Tarpon's Avatar
Dealer : Cloninger Toyota
2006 Toyota 4Runner,
2002 Toyota Tundra
Tarpon's Photo Albums
Last Online: 08-15-2007 08:57 PM
Tarpon is on a distinguished road.
Send a message via AIM to Tarpon
Default Full Float Axle Conversion
Front Range Offroad Fabrications now offers a kit to convert the rear axle of a toyota tundra to a full float axle. Front Range has built killer offroad toyota trucks for years and it's awesome seeing them make products for the tundra. Check out the kit at http://www.frontrangeoffroadfab.com/floater.htm
2001 Silver Tundra SR5
Mods:slimline ventvisors, TRD dual exhaust, TSC Toolbox, Protech 1" diff. drop spacer, Protech EZlift 2.5 in spacers, wheelers AAL, Extreme Alloy 1879 wheels, 285/75/16 Procomp Xterrains, Powertrax No-Slip, Hi-Lift Jack
Future Mods:Daystar 1 inch body lift, TeamWest coilovers, Camburg Uniballs, 4.56 gears, underdrive pulley, skidrow plates
Old 08-01-2005, 12:56 AM
TMS2U's Avatar
Dealer : Longo Toyota
TMS2U's Photo Albums
Last Online: Today 12:23 AM
TMS2U is on a distinguished road.
Brian has had that kit out for a long time already. My main concern with it is the fact that you are using a gear from vehicles that aren't as heavy as a Tundra. The kit works very well on Tacos tho and Brian is an excellent fabricator. The best part is the availability of a chromemoly axle shaft. Having gone thru rear wheel bearings, the need for an improved set up for the rear axle is there.
Old 08-02-2005, 06:51 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
it's good to see he's finally advertising that for a tundra as well as a t-100...i pestered him and mike (ORS) for a while about a year and a half ago about putting it on a tundra. regarding parts strength, the only failure they had was due to an improper heat treat on an early shaft; the splines twisted off during a maneuver, they were running 39s on a spool behind a v6 at the time, everything else was fine--the truck was (i think) the ORS "shop truck". it's a burly kit, i'd have converted a while back but i have (and would lose) the ABS.
if you're only going to run a "small" large tire and have a rational right foot, it'd be a great kit.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 08-02-2005, 11:14 PM
TMS2U's Avatar
Its not the shafts that worry me. I'm more concerned about using bearings, hubs, rotors, and calipers from vehicles that are around 1000#'s lighter than a Tun. Now if one were to do the same, but with 1/2 ton chevy gear.............
Having said that tho, I cant tell you how close I've come to going for it
Old 08-02-2005, 11:27 PM
jjc's Avatar
jjc jjc is offline
Dealer : Beaman Toyota Co.
2008 Toyota Tundra SR5 4x4 TRD,
2001 Toyota Tundra SR5 4x4 TRD
jjc's Photo Albums
Last Online: 11-20-2008 08:18 AM
jjc is on a distinguished road.
I looked into these prior to doing my rear disc brake conversion and came verrrrry close to pulling the trigger. The only thing that stopped me was the gear strength and the fact that the axles are turned down pretty small at the bearings. It sure would be nice for someone to come out with an aftermarket chromoly replacement axle for the factory ones also .
2001 TRD 4x4 with a lift kit & a bone stock 2008 TRD 4x4
My Junk - http://community.webshots.com/user/0...host=community
Old 08-03-2005, 02:10 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
If you find someone that makes some, let me know so I can start saving. I need to invest in some.
Mike - http://dyogim.blogspot.com
Old 08-08-2005, 06:21 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Mike Donofrio's Photo Albums
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
This seems like a good solution to a fairly common problem. I wouldn't worry so much about breaking the axles. Have any of you 'crawlers broken any yet? I think I'd be more worrried about bending the axle flange and the resultant runout creating a myriad of other problems.
We've all seen the failed bearings by now, it turns out that this problem can also frag the diff as well if the axles get too 'sloppy' I am just wondering when my rear bearings are going to go again. Especially since I jumped a curb by accident last week. ;-) Semi floating axles like the rest of our suspension don't really take into account any heavy duty usage for the Tundra--I am sorry to say. Not bad if you live by a guy that has a press. This is just getting ridiculous.
If it weren't for the motor i'd have traded this truck in years ago.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/lockrite.htm
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Similar Threads for: Full Float Axle Conversion
Solid Axle Conversion Island_Tundra Suspension & Axle 83 03-26-2008 10:46 PM
portal axle coilover conversion southerntundra Suspension & Axle 5 11-15-2004 11:22 PM
i thought the manual hub kit was full float. what gives? DevinSixtySeven Engine & Drivetrain 3 07-13-2004 12:02 PM
Solid Axle Conversion AZTUNDRA2000 Suspension & Axle 5 05-12-2003 05:25 PM
