This is a discussion thread titled "Upgraded Lower Ball Joints", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-03-2005, 09:02 AM
Dealer : Freedom Toyota
2001 Lexus LX470,
tundra61's Photo Albums
Last Online: 09-25-2008 06:07 PM
tundra61 is on a distinguished road.
Default Upgraded Lower Ball Joints
I have 2001 with DR coil overs. I have them set to around 2.5+ inches.
The truck has about 62,000 miles and I have had the lift for about 10,000.
I am really annal about keeping everything in top top shape and am planning on doing some front end maintenance in the near future. Also, I sometimes hear the infamous "clunk" when making turns.
So, I know all about the uppers and aftermarket UCAs but does anyone know if there is any type of updgrade for the lower ball joints? Even if it is not something like the uniball, are there any companies that make a better than OEM lower. (I checked my truck for the ball joint recall and it does not apply to me.)
Also, for those of you who have a CO lift, what kind of maintenance/replacement have you had to do with steering related components (other than new bushing). ie tie rod ends etc.
Since I am asking questions, what about bearing? Has any one replaced them and at what mileage?
Tundra61
Old 08-03-2005, 09:20 AM
H2O_MAN's Avatar
Official Taste Tester
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN's Photo Albums
H2O_MAN is on a distinguished road.
Tundra61
The replacement OEM lowers are better than what you have.
I just had mine replaced under the recall and they are a stouter design.
If you can't locate an aftermarket product consider the NEW OEM lowers.
Old 08-03-2005, 12:26 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
wait, so the new oem lower assembly fits the 00-02 lower control arm and spindle? i thought they were different starting in 03 or 04, or are you talking about an update to the original lower ball joints rather than the late model lower ball joint?
-sean
GFX by FreedomEagle50
Manual Hubs
Old 08-03-2005, 07:57 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 05:30 PM
Imdone is on a distinguished road.
I just replaced mine and they looked the same. I didn't see any difference. Mine are for a 00.
Work in progress...
Old 08-04-2005, 12:18 AM
Dealer : Poway Toyota
2004 Toyota Tundra
dezert_rida's Photo Albums
Last Online: 11-19-2008 01:35 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida
Tundra61
I dont know of any upgraded lower ball joints. Only thing you could do would be to get some 04 or newer spindles which accomodate 04 and up ball joints which use 12mm bolts as opposed to 10mm bolts.
Ive been all through the raised steering issue. I have my DREs set at 4" lift, with TC UCAs. I was getting a rubbing\scrapping sound on turns....I thought it was the inner tie rods scrapping the rack because the angle was huge. I converted the steering to use heim joints with a sleeve that threaded on to the inner tie rod, but i mounted them on top of the steering arm(after drilling it straight to 5\8") to greatly reduce the angle on the rack. I had it aligned right after. Well, i found rather quickly that not only did that not solve the problem(found it was coming from the uni balls on the upper arms) but now i have bumpsteer, which is kinda creepy.
I found that taking the bolt and missalignments out of the uniball and drowning it in molly grease while cycling it and ressaembling eliminated the noise. Now all i have left to do is buy new lower ball joints and outer tie rods to convert back to stock. The steering arm is part of the lower ball joints.
Old 08-04-2005, 09:01 AM
2001 Lexus LX470,
You are a brave soul "experimenting" with steering components.
Old 08-05-2005, 05:13 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
dsrtrcr01's Photo Albums
Last Online: Yesterday 08:53 PM
dsrtrcr01 is on a distinguished road.
Default Sounds
Sounds like a safe bet. Using Heims is stronger then tie rods. I am sure he used Grade 8 or at least grade5 bolts and everything else is stock. Sounds stronger then stock to me. But he did change the steering angles which caused the bump steer.
When your A-arm cycles it actually increases your track width. When you changed the angle of the tie rod it no longer had the same angles as the A-arms causing the bumpsteer because as your track width increased on compression but your tie rod did not get longer as it did when it had the same angles as the A-arms.
I built ALL my own steering for my desert truck. Idler arm from scratch, Centerlink, Tie rods, and Pitman arm. The steering box and shaft are stock.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 08-06-2005, 01:40 PM
2004 Toyota Tundra
Im using grade 8, 5\8" bolts. Theres no way those bolts are gonna break.
On my 94 2wd Toyota, im running 1\2" bolts through the heims on the outers, and 5\8" bolts on the inners....still using the stock centerlink, idler and pitman on that however. I beat the snot outta that truck and never a failure. Theres some play in the idler, but im getting ready to sell it anyways.
Old 08-17-2005, 12:24 AM
Dealer : Power Toyota Scion Tempe
2002 Toyota Tundra
lewisb62's Photo Albums
Last Online: 11-11-2008 01:15 AM
lewisb62 is on a distinguished road.
Default Ball joint recall
Think the dealership would also replace the bushing with the bj replacement?
(for free of course!
02 Tundra, SR5, desert sand (?)
Current Mods:
Unichip, 1" body lift, Wheeler's coils, rotors, pads, rims, Bilstin HD shocks, S&S headers,
Magnaflow system, Line-X bed liner, seat covers, TRD air filter, 35% tint, custom sliders.
In the Works:
Winch Bumper
Similar Threads for: Upgraded Lower Ball Joints
Lower ball joints leaking grease! supritdeol Suspension & Axle 13 08-02-2005 12:29 AM
Lower front ball joints??????????? Imdone Suspension & Axle 14 07-14-2005 07:51 PM
Aftermarket lower ball joints with grease fittings??? dezert_rida Suspension & Axle 3 03-27-2005 04:33 PM
What do Ball Joints sound like/act like when they are bad? Mike Donofrio Suspension & Axle 1 06-07-2004 05:30 PM
Replacing Upper ball joints? Diablo Suspension & Axle 5 02-20-2004 06:06 PM
