This is a discussion thread titled "Tundra 2.5" Lift Advise", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Just stumbled across this site the other day, it's awesome!! Lots of great information.
I have a 2002 Tundra TRD 4x4 and I absolutly love it.
I want to put a 2.5" suspension lift on it to give me room for 285/75 R16 BF all terrains and have some questions.
Pretty basic lift: spring spacers in front (2.5") and either add-a-leaf or blocks in the rear (1.5")
My first question is regarding the rear. I would prefer to use add-a-leaf because I feel that it is better than blocks. I know that it will stiffen the stock ride. Any thoughts??
Secondly, some kits contain front differential spacer kit to help strain on CV joints. Any thought????
Thirdly, has anyone put 285/75 R16's on the alloy TRD rims? Some of the reading I have seen recomends backspacing of about 4". I also understand that I could keep the tires from rubbing by adjusting the front bump stops. Any thoughts????
It would be great if you guys could help steer my in the right direction.
The add-a-leafs will not necessarily stiffen the ride. Typically the new spring goes next to the overload leaf and it only comes into play when a heavy load is placed in the bed. You will probably see about a 1/2" - 1" lift in the rear as a result.
The front diff spacer helps to maintain the correct angle between the diff and the CV's. I would recommend it.
For your 3rd question, I don't have any personal experience with that one. I'm sure others will chime in.
My daily driver - 2008 Yaris sedan 'S'. Tinted windows in the rear, TRD anti-sway bar for the rear, 17" rims - Samurai SC02 Hyper Black. TRD lowering springs.
My favorite ride - a 2001 SR5 4x4. With - RCD 6" lift, JBA Titanium coated headers, JBA y-pipe, Unichip PnP, ARB rd-129 air locker (rear), Camburg UCA's, custom front Sway-A-Way coilovers, custom Sway-A-Way's with remote reservoirs and billet mounts for the hind-quarters, PolyPerformance limit straps with adjustable clevis's - mounts welded up by AJ at BentUp.com, Stubbs Welding rock sliders and custom front skid plate, 315/75/16 Toyo Open Country M/T's, on all 4 corners wrapped around 16x8 MB Motoring Blitz rims, cryo'd 4.88's set up by Inchworm Gear, Trenz billet grill upper, T-Rex billet grill lower, on board VI-AIR aircompressor and 3 gallon air tank from Wheelers Off-Road, Inc, AutoMeter A-pillar pod with transmission temp gauge (sending unit in the tranny pan), Long Tru-Cool LPD tranny cooler, 10" Flex-a-Lite tranny cooler fan w/thermostat, TRD billet oil filler cap, TRD air filter, TRD dual exhaust, and TRD add-a-leaf rear springs. Superlift TruSpeed Speedometer Recalibrator. Warn Trans4mer Grill Guard, brush guard and 9.5ti winch w/cover. Budbuilt traction bar. Wheelers Off Road Centric performance brake rotors: cross-drilled and slotted. Staun tyre deflators set for 13 psi. Our home away from home, 2004 Outback 26RS travel trailer with 15" MB Motoring Blitz rims to match the Tundra.
Welcome Stuart!!
Originally Posted by stuartg77
My first question is regarding the rear. I would prefer to use add-a-leaf because I feel that it is better than blocks. I know that it will stiffen the stock ride. Any thoughts??t
I'd have to agree with Herbicidal. AAL's won't nessesarily stiffen the ride.
Secondly, some kits contain front differential spacer kit to help strain on CV joints. Any thought????t
That CERTAINLY is a wise investment, especially considering that you're looking a 2.5" of lift. I bought my diff drop kit from another TS.com member, primarily as a "precautionary measure". Nothing like a little preventative maintenance. Of course the alternative of leaving this kit out, could and has for some TS.com members, caused the CV boots to start spewing grease, with a 2.5" lift.
The "stock" alloys don't have enough back spacing to accomidate the 285's, no matter how much lift you use. You'll have some frame rub any way you look at it, using the stock TRD wheels. Most TS.com members here who have opted for the 285's, have had to purchase a set of aftermarket wheels with more back spacing. Not sure how much exactly, but something tells me, you're at least in the ball park with 4".
Never heard this one?! It's certainly news to me. Maybe another TS.com member can help on that, although I have my doubts that this is correct.
__________________ 2004 SR5 Double Cab 4x4 w/TRD Pkg. Mods to Date:
16" 5 Spoke Brawn Enkei Wheels, Keyless Entry, Line-X Bed Liner, Challenger Running Boards, Husky Floor Liners, Bug Flector II (painted to match), Colegan Bra, Borla Dual (Side-Exit) Exhaust System, 2" Wheeler's Coil Lift, TRD Add-A-Leafs Mods to Come:
265/75/16 BFG A/T's, Possible Mods:
I am running 285/75 R16 bridgestones on the stock rims. The tires fit, but you will rub on the frame with the driver side tire. You can either go with a rim with less BS, but it will put more tire into the rear of the fenders when you turn.
To adjust the steering stops, you just tack weld on some spacers ie 1/2" or 3/4" nuts on to the opposite steering stop. To find the steering stop, just turn your wheels and have a look near the bottom of the spindles on the front side.
