This is a discussion thread titled "alignment question", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I have a 04 DC 2WD that I am seriously thinking about putting the daystar coil spacers up front to level out my truck (the raked look is stupid). My question is not how to do this but what alignment issues you all have had with this modification?
2001 Toyota Highlander Limited
3.0V6 4WD
No modifications...kinda like it the way it is!!
2006 Nissan Frontier XE
2.5I4 RWD
All kinds of mods, but it will never replace my Tundra in my heart! By the way, this truck SUCKS compared to Toyota.
Sorry to hijack this thread but I have a question about after adding a lift and adding larger wheels and tires. When you go in to do the alignment, do you need to have the larger tire/wheel installed on the truck or can you go in with just the stock wheels? The reason why I asked is because the shop I brought my truck to today could not do the the alignment because of my aftermarket wheels. Something about the gauges could not go on (fit) on the aftermarket wheels. They requested to have the stock wheels/tires put on for the alignment. Will I get an accurate alignment if I have the stockers on?
I have run accross this many times at work. The tires are just to tight on the wheel to allow the HUNTER (best machine out there) heads to be attached. You would almost have to beat them on and risk damaging/scratching the wheel. I always either ask the customer to bring in the stock wheels or have on occasion swapped a set off of another vehicle in the shop to get the job done. The tire size diff may or may not make a small bit of difference, but if the heads dont fit they dont fit. What else are you going to do. It will get you a alignment as close to perfect as you can get. I wouldnt worry about it. You will get a good alignment with the stock wheels. I have never had a problem.
23 yrs with TOYOTA
Thanks for the spec link. I will definately get this done. My kit is on order from wheelers...I decided to go with the 1.25 coil spacer because Gary over there said that it will get it pretty close to level without touching the rear.
3.0V6 4WD
2.5I4 RWD
23 yrs with TOYOTA
That is EXCELLENT info to have Victor!! I would NEVER have thought of that. Truth be told... I'm willing to bet... that most tires shops... wouldn't think about it either. And rather than do it right, they would either risk destorying somebody's wheels, or just do a... ummm... half-a$$ alignment job and call it good.
MANY thanks... .
__________________ 2004 SR5 Double Cab 4x4 w/TRD Pkg. Mods to Date:
16" 5 Spoke Brawn Enkei Wheels, Keyless Entry, Line-X Bed Liner, Challenger Running Boards, Husky Floor Liners, Bug Flector II (painted to match), Colegan Bra, Borla Dual (Side-Exit) Exhaust System, 2" Wheeler's Coil Lift, TRD Add-A-Leafs Mods to Come:
265/75/16 BFG A/T's, Possible Mods:
Hunter alignment heads can be used with nearly any wheel. I say "nearly" because there might be some types that I haven't yet seen and so my kazoo is covered.
If the wheel clamp won't clamp directly onto the wheel because the tire is too tight a fit to it (which happens with some tires and wheels), then a different method is used. The probes that clamp to the wheel are replaced by shaped rubber pads that fit against the wheel, and then a ratchet strap around the tire is used to hold the whole thing against the wheel. It works just fine (been there, done that), but not every tech has the parts, remembers where they are, or is willing to use them.
Such will remain the case until tire manufacturers wake up and concentrate on reality instead of on cosmetics. I ain't holding my breath.
Thanks for the great Tip. I didn't even know they had such a device. I dont personally get to talk to our Hunter REP, so I will be asking our manager to call Hunter and find out about getting a set of these rubber pads w/staps. That sounds a whole lot easier than having to find a vehicle to swap out wheels with.
See, I learned something new today.Gotta love TS
Thanks AGAIN
Victor
23 yrs with TOYOTA
TundrastruckDave, I noticed you put the 2in lift system on your truck. Looks good What size tires are you running on your DC?
Hey Nate,
Thanks for the compliment.
Unfortunately, at present... the tires on my DC... are those 'ole crappy BFG Rugged Trails in the "stock" size of 265/70/16 . Right now, that's just the way it's gotta' be, until I can find the "extra" cash to replace them.
In the long run though, I'm hoping to end up with a 265/75/16. That's just large enough to "fill-up" the wheel wells nicely, and satisfy my desire for a larger and more aggresive looking tire. Not to mention... FINALLY... having a set of LT (i.e. Light Truck) rated tires on my DC, instead of those BFG Pmetric (i.e. Passenger) rated pieces of junk!
I STILL find myself wondering... what in the hell... Toyota was thinking, when they decided to use those tires on the Tundra in the first place?!
They were thinking money.
You can buy the BFG Rugged Trails for about $45 or so retail. The Michelin LTX M/S is about $125 or so, minimum. Toyota makes about 150,000 Tundras per year. The savings are:
(125 $/tire - 45 $/tire) x 5 tires/vehicle x 150,000 vehicles/year = $60,000,000/year
Over the last five years, that's THREE HUNDRED MILLION DOLLARS they've not spent.
DJ,
Are these prices real? I looked up the BFG's prior to selling mine and saw them at Tire Rack for about $119 each. I ended up selling mine fairly new for $50 each, I wonder if I got a great deal if that's the price you're finding for the BFG's.
My dad just traded in his tundra and I took the wheels off of that. They are 265/70/17s, no names, practically brand new. Now all I have to do is lift the front end so it doesn't look as stupid. If were my choice (ie, I had the money) I would put a nice set of rims and BFG A/Ts on it. Well, the family comes first...
3.0V6 4WD
2.5I4 RWD
