This is a discussion thread titled "Need Advice:06 Dc 4wd, Cornfed/Revtek/Daystar?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-12-2006, 11:29 PM
Inactive Account
Dealer : Crown Oldsmobile Toyota
tjvance55's Photo Albums
Last Online: 05-14-2006 10:45 PM
tjvance55 is on a distinguished road.
Default Need Advice:06 Dc 4wd, Cornfed/Revtek/Daystar?
Need Advice:06 Dc 4wd, Cornfed/revtek/daystar I need advice and opinions please! Wanting to do a 2.5 lift. Money is not really an issue between the three. Wanting to try to maintain factory ride or better. Very little off roading, mainly snow. Basically for looks with a bigger tire prob. 285 75 16 on a mt classic II. Several unanwsered questions: aluminum or steel, spacers on top/bottom/or in, differential drop kit or not, blocks or aal, limit straps or not, factory shocks or bilstein trd's front and back, will the spacers rust or not, and do i need to change the cv boot clamp? anwsers to these questions would be greatly appreciated. can anwser on tundra solutions or email me with thoughts and or pictures tjvance55@yahoo.com. just bought my tundra last week and am itching to raise the thing. all the lifts i have seen on here are awesome. thanks for any advice or opinions!
Old 01-13-2006, 12:33 AM
TacomaOffRoadGrl's Avatar
Dealer : Younger Toyota
2005 Toyota Tacoma,
2007 Toyota FJ Cruiser Sun Fusion
TacomaOffRoadGrl's Photo Albums
Last Online: 08-14-2008 10:53 AM
TacomaOffRoadGrl is on a distinguished road.
Default Re: Need Advice:06 Dc 4wd, Cornfed/Revtek/Daystar?
Well any lift is going to change the ride. Better than stock...well that's a matter of opinion I guess. The ride will be stiffer than stock. If it is merely for looks basically I would either get the Toytec spacer lift or wait for the OME/Toytec lift that will give a better ride than a spacer lift. The Toytec lift has an in the coil spacer for the 2.5" lift. If you only go 2.5" you really don't need a diff drop either. With 2.5" of lift and 285 tires you will have some minor rubbing...at least I do anyway. I would go with the aluminum spacers over steel, AAL instead of blocks, and you can keep your stock shocks if you want and you don't need limit straps. Hope that helps some. Oh and you might get more responses on this in the Tacoma forum.
The New - - 2007 Sun Fusion FJ Cruiser
Deep Cycle Battery-Running Boards-That's It For Now But Not For Long
The Old - - 2005 Tacoma TRD Off-Road (I Miss My Baby)
Dual Optima Batteries-Toytec Lift-MB Motoring Wheels-285/75/16 Nitto Grapplers-Waeco Portable Fridge/Freezer-Yakima Roof Rack-Softopper Canvas Top-Airaid Intake Kit-Billet Grille-Flowmaster 40-Aries Nerf Bars-Tint-Wade Hood Protector-TRD Seat Covers-Bed Extender-Toyota Bed Mat & TRD Floor Mats-XBar Light Bar
Old 01-13-2006, 11:53 AM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 11-18-2008 07:24 PM
Let me answer your questions... one by one.
... that sure must be nice!
Like (TacomaOffRoadGrl) said... "any lift is going to change the ride. Better than stock...well that's a matter of opinion I guess. The ride will be stiffer than stock. If it is merely for looks basically I would either get the Toytec spacer lift or wait for the OME/Toytec lift that will give a better ride than a spacer lift. The Toytec lift has an in the coil spacer for the 2.5" lift.If you only go 2.5" you really don't need a diff drop either. All of this is pretty much fact. However, I do disagree with (TacomaOffRoadGrl's) last comment, about NOT needing a diff drop kit. As proof of that take a look at THIS THREAD, which was started just yesterday. That said... you're definately going to have to address this issue with 2.5" on a Tundra. In fact, that's "part" of the reason, I only went with a 2" lift on my DC. But other than that... I concure with (TacomaOffRoadGrl). Also, if your do decide to go with 285's, you will need those mt classic II's. It's the ONLY way you'll get those 285's under a DC. Even with those however, you'll more than likely have to remove your front mud guards, as other TS.com members (with DCs) have had to do.
If you've looked at the link, which I provided on my lift, then you know I'm not a big fan of spacers, as I believe coils are a little better alternative. But that is of course, just "my" personal opinion. I certainly can't completely disagree with spacers, as there are MANY Ts.com members who have them on there Tundras. Having said that, I'll leave this one up to what "you" would prefer.
I'd say... "YES". Reference my comments above.
blocks or aal
Again I have to agree with (TacomaOffRoadGrl) on this one. I think you'll enjoy the ride much better with AAL's over blocks.
limit straps or not
Subjectionable... at best. However, if you DO plan to off-road any, then I would CERTAINLY remcommend them. Nothing would spoil your day any worse, than a blown-out shock.
Your preferance. Obviously most TS.com member "do" upgrade, when they do a lift. In my case however, I already had the TRD package with the bilsteins, so I just used what I had. If you're considering the HD bilsteins, then that too, might stiffen the ride a little, so just keep that in mind as well.
Can't subjectively give you an answer here, since I don't have them. I would however, think the machined steel might hold up better.
It's certainly possible. It might even be a good idea to do it anyway, as a precautionary measure, BEFORE the grease leaking can even being... if it even does... that is.
Well there ya' go... I've played 20 questions with ya' now. Hope the answers help...
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Similar Threads for: Need Advice:06 Dc 4wd, Cornfed/Revtek/Daystar?
Need Advice:06 Dc 4wd, Cornfed/revtek/daystar tjvance55 1Gen-Tundra 11 07-21-2006 05:52 PM
97 4Runner Limited 4WD engaging problem 4RUNN!N Engine & Drivetrain 0 11-29-2005 03:45 PM
Help! 4WD will not disengage! bdr98 4Runner 0 06-06-2005 02:21 PM
Need a 4WD Tundra that looks like a 4WD Sequoia2003 1Gen-Tundra 4 01-30-2003 06:59 PM
