Re: Replacing ball joints
the uppers are more difficult than the lowers but both are preety simple with the use of the right tools. you will need a ball joint press (you can rent one at the auto parts store) a big honkin hammer, or an air chisle. a pickle fork can be a help but is not 100% ness. and yes it is easier to remove the whole knuckle to get the job done right.
the lower is also under recall so let the dealer do that one.
on a side note, have you considered going ahead and upgradeing the upper ball joint to a uniball instead of the weak factory unit?
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
