This is a discussion thread titled "DriverSide Rear Sag", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-30-2006, 06:56 PM
JAW's Avatar
JAW JAW is offline
Dealer : Woodhaven Lexus Toyota
2003 Toyota Tundra
JAW's Photo Albums
Last Online: 12-03-2007 09:33 AM
JAW is on a distinguished road.
Default DriverSide Rear Sag
I am noticing what appears to be an increasing problem of sag or at least what appears to be sag on the drivers side when walking up to my truck from behind. I only have 60 000 miles on my 03 Tundra, about 40 000 on wheeler AALs. The sag appears to be much more pronounced when I have a full tank of gas which makes sense I guess. But I estimate the difference of about 2" when comparing the axle line with the bumper line from left to right. Should I be concerned, is it possible I have a blown shock, or did I maybe get a bum AAL on the drivers side? I have always had a slight difference but it seems to be getting worse. It doesn't seem to effect the handling of the truck, but than again maybe I don't know any better.
[font=Book Antiqua]2003 TRD Off Road Acess Cab.
Current modifications: Wheeler Coils and AAL, Limit Straps, Line-X
Old 01-30-2006, 07:09 PM
greener's Avatar
Dealer : Toyota of Des Moines
2003 Toyota Tundra
greener's Photo Albums
Last Online: 10-24-2008 05:51 PM
greener is on a distinguished road.
Default Re: DriverSide Rear Sag
I put a shim on my drivers side, 1/8" stainless steel. Had a local metal shop stamp one out for abouot 5 dollars.
Old 01-30-2006, 07:16 PM
JAW's Avatar
JAW JAW is offline
2003 Toyota Tundra
JAW's Photo Albums
Thanks
Why not! Sounds like an easy fix and I guess it is safe although given the difference I would be inclinded to put in a half inch shim if it will fit (u bolt length an issue) to help make up the difference.
Similar Threads for: DriverSide Rear Sag
Has anyone performed the Rear Brake TSB on their Sequoia? Jettix2 1Gen-Sequoia 4 07-16-2005 01:35 PM
From Tundra to F250 back to Tundra?? (Towing) Tony1790 Towing 33 05-13-2005 10:40 PM
Sequoia Rear Disc Conversion sknaus Suspension & Axle 5 05-10-2005 10:54 AM
Tacoma: Tacoma Differential Q & A or Comments WillardBubby Engine & Drivetrain 95 03-07-2005 11:09 AM
Effect of changing front or rear height on caster Genthar Tires and Wheels 2 08-11-2003 11:25 AM
