This is a discussion thread titled "Tundra Rear Block Lift Tips", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I just got my 1 inch block lift from www.wheelersoffroad.com and I was wanting some install tips and such. Can anybody help?
Toyota Tundra TRD 4WD Limited i-force V8
1.2.5 Inch Coil Spacer
2.1 Inch Rear Block Lift
3.Diff Drop
4.Rear Bilstein 5100s
5.Pioneer Head Unit
6.XM Radio(Pics Coming Soon)
7.InDash CB radio
8.K40 antenna
9.SS Autochrome Headers
10.Borla XS Muffler(Dumped)
11.Remote Start and Door Lock
12.Tool Box
13.Step Bars
14.Window Trim Visors
15.Front Skid Plate
16.Off-Road Lights Mounted on Tool Box
17.16x8 M/T Classic II
18.Cold Air Intake
19.10' JL Sub
20.JBL Amp
21.Debadged
22.Baja Bar
23.Hella 500's
1986 4runner 22RE Auto,4WD,EFI.
I bought this 4runner for $200. Currently its not running but I hope it will soon. I got some sweet plans for it. Post pics as I go.
chock the front wheels.
use jackstands on the frame before the axle.
put a jack under the pumpkin or one on either side. don't lift the truck off the jacks though.
loosen the 4 nuts for the U-bolts and remove.
lower the rear axle enough to get the block in.
Place the block.
Put the new (longer) U-bolts on and tighten.
Use the jack/s to lift the truck up off the stands.
remove stands and lower.
Check out new 1" lifted rear.
Pretty simple, 1" is cake. Try 4" blocks, that's a real PITA!
Work in progress...
LMAO! Plus that you said "lifted rear", mmmhhhh, mmmhhhhhh.
__________________ "Si vis pacem, para bellum"-Vegetius
2005 Tacoma Doublecab TRD Offroad 4X4 shortbed - Modifications - Fog light mod, Debadged, Black Toyota grille emblem, Map Light Mod, DRL mod
Factory Accessories - Tacoma Bedmat, Extra set of D-rings installed in front bed bolts, Extra set of factory tie downs
Optional Options - FilterMag, Fumoto valve, Westin Suregrip running boards w/LED lights, WeatherTech Floorliners, WeatherTech window visor vents, Prestige remote car starter w/keyless entry, SilverStar headlight and turn signal bulbs, Toytek 2" lift, Muth heated signal mirrors, WAAG grille guard (center only, I'm old school), Taillights tinted by JonsTintedTails.com, Anthracite FJ Cruiser wheels w/ 265/75r16 BFGoodrich A/T
im not going to try and be a dick but honestly if you dont know how to install blocks you shouldnt even try. its about the easiest thing you can do and just about any joe blow with some tools could figure it out just by looking.
does anyone know where to get 2 inch rear block kit? i found blocks but they dont come with the u bolts. anyone know where to get the complete kit? also, do i need to change the shocks? besides the brake proportioning bracket will i need anything else for this lift? thanks.
2006 Natural White Tundra SR5 4x4 DC sold
2007 Honda Civic Si Sedan tafetta white
DISCLAIMER: Poster makes no guarantee that the above expressed information is accurate, complete, current, funny, new, spelled correctly, or grammatically correct. The above-stated information is instead provided on an "AS IS" basis, and is subject to revision with or without notice.
take it to the professionals.
You ARE sounding like a dick and why shouldnt he try and learn how to do things himself instead of taking to a shop, who will likely charge a ridiculous price for this. Its always better to learn how to install your own parts so when something goes wrong you know how to fix it. Give the guy a break.
I have 2" blocks and got them from suspensionconnection.com. They are from Tuff Country.
It did not come w/ the longer U-bolts but I already had a lift on it and I just used the previous ones. Most shops can get them for you seperately. My local shop offered to get them for me.
You can also check PerformanceLifts.com also. They offer longer U-Bolts right on the lift block page.
http://performancelifts.com/cgi-bin/cart/FTSBK2.html which u bolts should i get for my tundra? too many options in the dimensions. also, do i have to change shocks for a 2 inch block lift? i know mostly everyone would agree that it is recommended but what r the risks if i dont change them?
Hope this helps.
thank you lexus luthor. it is exactly what i was looking for.
you dont have to, but you do risk blowing the shocks. drive carefully over whoops in the road, otherwise the shocks will max out and rattle your fillings. i suffered through this for about 3 years before getting some used longer shocks.
