This is a discussion thread titled "another lift kit problem", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-08-2006, 09:23 PM
Dealer : Boulder Toyota
2004 Toyota Tundra
JasOnK's Photo Albums
Last Online: 12-06-2006 12:27 AM
JasOnK is on a distinguished road.
Unhappy another lift kit problem
I've tried searching and haven't found much on this, so I though I'd post a new thread and see if anyone else has had this problem and how they fixed it.
Anyway, the problem is with a my front suspension. When I come off of even a small bump or pothole my front suspension slams back down pretty hard. It doesn't sound good at all!! This started after installing a Toytec 3" spacer lift on my 04 Tundra access cab 4x4. Installed by 4 wheel parts. I'm thinking of removing the top spacer and going down to 2 1/2" lift. any other ideas?:
Old 02-08-2006, 09:34 PM
2004 Toyota Tundra
Default Re: another lift kit problem
oh yeah, Toytech says He's never heard of any problems like that.
Old 02-08-2006, 10:46 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 05:30 PM
Imdone is on a distinguished road.
It's the size of the spacer in the coil pack that is causing this, not the one on the outside. Yes everyone has heard of this, it is called compressing a spring more than stock and then releasing it quickly it will move at an accelerated speed thus making the slam. I had the same problem with the cornfeds.
If you get a daystar kit instead you won't see this problem so much because they use a smaller spacer in the coil pack and a larger one on the outside.
Work in progress...
Old 02-09-2006, 10:14 AM
TIE-YOTA's Avatar
Dealer : Ron Carter Toyota
2004 Toyota Tundra
TIE-YOTA's Photo Albums
Last Online: 02-08-2008 02:52 PM
TIE-YOTA is on a distinguished road.
I noticed the same thing on my DC. However, I have had mine on for about five weeks now and have noticed the springs have started to soften up. Just an observation. Also, do you have AAL's in the rear? That could be applying more compression than necessary which also could be a contributing factor.
Previous Trucks Owned:
1990 Toyota Xtra-Cab 2wd (145,000 miles)
1996 Toyota Tacoma Ext. Cab 4wd (171,000 miles)
2004 Toyota Tundra DC 4wd (Phantom Grey - 48,700 miles and counting)
Toyota truck user for 16 years and counting..........
Also known as Thibodeaux at the Fuge.
Gig'em Ag's (Class of '94)
Modifications on DC to date:
3" Toytec lift, 1.5" Add-A-Leaf, Line X, Eagle Alloys Series 101 16x8 (3.60 B.S.), 285/75/R16's Cooper Discoverer ST's
Old 02-09-2006, 07:14 PM
2004 Toyota Tundra
yup, I have the 1.5" add a leaf. It sounds like this is pretty common with a spacer lift. I think I'll take out the top spacer and and hopefully the spring will soften up after a while.
Old 02-09-2006, 07:24 PM
2004 Toyota Tundra
It looks like both spacers are inside the pack to me, but I don't know jack about suspension. It looks the same as this picture www.toyteclifts.com/install3.html
Similar Threads for: another lift kit problem
K&n Gen Ii Intake Kit nhparrot Engine & Drivetrain 2 07-06-2006 11:19 PM
Lift kit question MATRDguy 1Gen-Tundra 1 01-05-2006 05:44 PM
Which 3" Lift Kit?? njmudslinger Tacoma 11 11-13-2005 07:31 PM
Free Lift Kit! Danno 4Runner 19 03-14-2003 02:47 PM
Lift kit for the taco BIGTUN Suspension & Axle 6 01-09-2003 03:38 PM
