This is a discussion thread titled "Revtek lift, sequoia rubbing control arm", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Just put the revtek lift on a 2004 Seq. Put 285/70R17s on the stock wheels. Have a bit of rubbing going on the a-arm at full turns. Think a wheel spacer will fix that? I don't want the wheels sticking outside the wheel well though.
You don't want wheel spacers they will give vibrations and excessive wear on steering components. Upper control arms correct ball joint angles and also give more clearance between tires and arm.
__________________ My 03 Tundra v6 AC SR5 mods:URD lightened crankshaft pulley(soon) | Xtreme Alloy 1079 | 285/75-16 BFG's | Spintech ProStreet dumped | Total Chaos str/rck bushings |Camburg UCAs| TRD 4X4 v8 coil | Daystar 2.5" spacers | TRD yellow-blue shocks | 5100's |No-Slip Locker w/Mobile1 synthetic dif. oil | B&M transmission cooler | 911 performance brake pads | Hellwig swaybar(need quick disconnects) | Front seat covers | 35% Tint 2 front windows | Drop-in bed liner | clear-red-clear tail lights | Clear corners | AMI 21" polished antenna | Challenger steps | Toyota skid plate | Demello bed bar w/ cheapo fogs re-wired and running 100w H3's | Color matched mirror covers| Debadged | PermaShield teflon
Is shaving safe? Looks like it would jeapordize the structural integrity of the control arm? Found the Camburg upper control arms for $439. That something a big-o tire would be able to do? Need an alignment as well.
I ended up just swaping out wheels. After looking further I was also rubbing on the frame. The solution was new wheels with a 4.5 inch backspace. Stock 17's were 5 inch. Just a little rub now on the mudflap which I will be triming one of these days.
