This is a discussion thread titled "Hellwig owners..please check in for possible issue.", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-26-2006, 06:16 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Verndog's Photo Albums
Last Online: 10-29-2008 07:37 PM
Verndog is on a distinguished road.
Default Hellwig owners..please check in for possible issue.
I am troubleshooting what seems to be a minor but irritating issue. When it is cold I feel and a slight hop from the rear of the truck, similar to out of balance feel from 40-50 MPH. So far I now replaced tires with Revos (looking for a reason anyway), re aligned to DJ's specs, changed rear diff fluid, and road force tested all tires with the correct 5 lug adapter for aftermarket wheels.
The issue is more prominent when it is cold out, then settles down some after about 5 miles or so.
I now am wondering if the Hellwig bushings are getting hard (cold) and inducing some hop type bump feeling from the non perfect but smooth "looking" road surface. If you look at the design, the brackets solid mount right to the rear end and tight bushings could possibly translate a bump feel there. I never noticed this before till 2 months ago, and have had it better then 2 years.
Anyone else notice anything like this? I may just pull it and test.
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 02-26-2006, 06:36 PM
monolithic's Avatar
Dealer : Conicelli Toyota Scion of Conshohocken
2004 Toyota Tundra
monolithic's Photo Albums
Last Online: Yesterday 07:18 PM
monolithic is on a distinguished road.
Default Re: Hellwig owners..please check in for possible issue.
No problems here.
2004 Toyota Tundra V6 Reg Cab 2wd Auto (Phantom Gray)
Options - Tilt wheel, Intermittent Wipers, AC, Mudflaps, Cold weather package, Bed liner (removed), Carpet floor mats, Trailer hitch receiver, Door sill protectors
Mods - Cruise Control w/factory dash indicator, Hellwig Anti-Sway Bar, Chromatic Mirror w/Temp & Compass, Phantom Gray Door Edge Guards, PT Industries Raptor SS Nerf for Access Cab, Fog Lights w/Factory Head Lamp Switch; Great Covers velour seat cover, 2004 Reg Base Cab Cargo Light Mod (use factory switch, no light when door opened), 2004 Reg Base Cab Auto Headlight Off Disabled Mod (lights stay on when door opened); SR5 Chrome Wheel Arch Moldings; Chrome power & heated side mirrors w/factory heat switch;Burlwood control faceplate & door switch panels; Overhead console w/garage opener & Luxeon Star LEDs; Alpex #244 Chrome dual air horns - 118db - 405Hz/450Hz - 15A; Horn baffle removal mod; Rostra Radar Backup Sensors;Pilot PL-250 Backup 55w Lights; H4 Osram Silverstar Headlights; Enkei Brawn II alloys; 245/70/16 Revos; Power Outlet Mod; Ltd Visors w/lights; RainTracker rain sensor; Factory power windows; Manik tail light SS guards #925659SP; Power door locks (DEI relay module 451M); ATS grill;ARE MX camper shell (full side screens & w/o vista window); CompuStar 2W900FM(S) Remote Start/Keyless Entry/Ignition Auto Lock;Bed Carpet Kit w/Couch & Storage Boxes; Pop&Lock PL8500 Pwr Tailgate Lock; WeatherTech Mats, TRD LSD
Old 02-26-2006, 06:47 PM
student's tundra's Avatar
Dealer : Longo Toyota
2003 Toyota Tundra,
1998 Toyota Camry Daily Driver
student's tundra's Photo Albums
Last Online: 11-20-2008 03:43 PM
student's tundra is on a distinguished road.
Afraid I haven't noticed anything like that either.
2003 Tundra Imperial Jade TRD offroad
Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed
Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade
Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Old 02-26-2006, 07:49 PM
Verndog's Avatar
2003 Toyota Tundra
Update:
I just removed the sway bar, and found that a couple of the rubber dampeners had shifted from when I originally mounted them, I could see a "clean spot" where they used to be. Also I found 2 of the washers that carry much of the force where the front body end connect bars mount, were cracked, one almost clean in half.
I test drove and general straight away driving felt smoother. I will need to drive a couple of days, and especially when cold to confirm my suspicion. At best their mounting hardware is highly suspect and prone to wear. Also...I pamper this truck, if you push your truck very hard off road I would imagine it would be even worse.
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
Old 02-26-2006, 08:42 PM
H2O_MAN's Avatar
Official Taste Tester
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN's Photo Albums
H2O_MAN is on a distinguished road.
I push my truck very hard with high-speed turns and transitions.
I have had zero problems with the Hellwig and its mounting hardware.
I imagine you have/had an installation issue.
Request new hardware from Hellwig and re-install the bar making sure to properly torque all nuts and bolts.
Or better still, have a local shop install it for you.
Make sure you re-check the installation a week or two later.
Old 02-26-2006, 09:28 PM
biggary's Avatar
Dealer : Earnhardt Toyota
2001 Toyota Tundra,
2004 Toyota Camry-Solara
biggary's Photo Albums
Last Online: 11-11-2008 10:57 AM
biggary is on a distinguished road.
I have noticed something similar when cornering but I attributed it to the "floating" rear axle. When I turn a corner hard, it feels like the rear end is hopping as well as shifting to the side. In fact, it is such a weird feeling I have had to back off the throttle for fear that something is seriously wrong. Most of my driving is on the freeway and I haven't felt anything going straight. I have checked and re-torqued all bolts but will have to take a closer look at the hardware problems you discovered.
Factory: Leather, Tow Pkg., Tundra Floor Mats, RS 3000 Security, Six Disc In-dash CD Changer, TRD Off Road Package, Toyota bed extender, auto-dimming mirror, and running boards
Add-ons: INYATI bed liner, Lund hood deflector, Stainless Billet grille, Full tint, Tundra Door sill protectors, Putco s/s bed caps, Delta polished aluminum tool box, Whelen four-way strobe, Bridgestone Dueler A/T Revos 275/70/16's, Throttle Body and Relay/Fuse Billet Covers
Performance: True Flow intake and air filter, 20% Underdrive pulley, Jet Hot SS Autochrome Headers, Power Stop Cross-drilled Rotors & Maxxis Pads, Flowmaster cat-back dual exhaust.
Audio: Alpine V12 amp, Kicker two-way front speakers, Rockford-Fosgate two-way rear speakers, Boston Rally Neo 3r tweets, Phoenix Gold 500.1 sub amp, Twin Rockford-Fosgate 8's in a Q Logic sub enclosure, sound deadening, XM SKYFi2 Satellite Radio
Suspension: Revtek 2.5" suspension lift ,1.5" rear leveling block, Hellwig anti-sway bar w/ ADDCO end links, TRD Red/Blue shocks, TRD Add-a-leafs
Mods: Rear seat angle, Dome/ Dash/Fog/DRL and Cargo Light Mods,Under carriage lights, Ignition Key and Open Door Chime Mods, Silverstar head and fog lamps, Power tailgate lock
Old 02-26-2006, 09:42 PM
Verndog's Avatar
2003 Toyota Tundra
There was no issue with installation. I did it myself, and have been a machinst and tool design engineer for 27 years. Now if I had it installed then I might worry about that. I did not think I had a problem with hardware either. I was looking for the source of the rough ride and didn't see this till it was taken apart. You can not see the cracked washers while it's installed, they are sandwiched. The washers supplied are too thin and week, and the long spacer tube that all the force to the body goes thru is too thin IMO. I could see that during installation but went with it anyway.
I'm not saying you or anyone else will have this problem, just pointing out the possibility and potential source as a heads up to others that experiance a change in characteristics.
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
Old 02-26-2006, 09:47 PM
H2O_MAN's Avatar
Cool Part II
... I had this problem with the Hellwig on my T100.
I installed the bar back in '99 alone in my driveway.
I was zipping through one of my favorite S turns (posted
+40 mph) and felt a snap followed by a weight shift.
Not a pleasant feeling! The truck tipped away from the turn.
I stayed in the throttle, corrected my drift then lifted off the throttle.
I pulled off the road and check to see what broke.
I found the clean spots Verndog mentioned and noticed the link rods
were slanted a bit. The entire bar had shifted to one side!
I tried to fix it twice then had Hellwig send me new updated
hardware and had my local tire shop re-install everything.
I never had another problem and drove the T100 another 100K.
Old 02-26-2006, 10:33 PM
rcjunkie's Avatar
Dealer : Dublin Toyota Scion
2000 Toyota Tundra,
2004 Toyota Prius Package #9,
- Other - 02 Nissan Maxima SE
rcjunkie's Photo Albums
Last Online: 09-19-2008 09:23 AM
rcjunkie is on a distinguished road.
Just checking in. I've only had my Hellwig Anti Sway bar for about 5+ months and it's to early to notice anything wrong. Thanks for the update with your issue, it may save me some trouble-shooting in the future.
Ivan Stewart Signature Edition
Old 02-26-2006, 11:06 PM
imjin's Avatar
Defiant ut Terminus
Dealer : McGeorge Toyota
imjin's Photo Albums
Last Online: Yesterday 08:02 AM
imjin will become famous soon enough.
I haven't noticed it, but now I gotta check it out. I think I've had mine on about a year now.
Mods: Mickey Thompson Classic II | Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Old 02-26-2006, 11:09 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: Today 11:16 AM
SATundra is on a distinguished road.
Had mine on for 4 years now, no problems at all. But thanks for pointing that out to us. I will know what to look for if it starts sounding weird back there.
I also thought the long tube looked weird when I originally did my install, but like you went on installing it. Luckily no problems to date.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 02-27-2006, 10:26 AM
Dealer : Camelback Toyota Scion
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
tempetom's Photo Albums
Last Online: Today 10:37 AM
tempetom is on a distinguished road.
I was tempted to use the thinner washers at the spacer locations, but didn't think that would be as strong as the thicker ones. I did end up grinding some of the spacer down. So far, the spacer seems strong enough for its purpose. It's smart to check the tightness of the bushing hardware periodically though. I had some noise back there when hitting bumps and that was my problem.
Old 02-27-2006, 10:13 PM
MATRDguy's Avatar
Dealer : Ira Toyota of Danvers
2002 Toyota Tundra
MATRDguy's Photo Albums
Last Online: 09-30-2008 06:08 PM
MATRDguy is on a distinguished road.
has anyone had to cant / angle they're u bolts back or fwd to make the endlinks straighten out??
i'm still getting some 'plowing' in turns and i dont think i should be. any suggestions??
the bar was installed 4 days ago
Old 02-27-2006, 10:49 PM
2005 Toyota Tundra,
I was just looking at mine this evening and one of my end links is cocked a little. I think there's all kinds of room for adjustment in the big hole in the frame. I don't look forward to fighting that battle again, but when I get around to it, that's the route I'm going to take.
Old 02-28-2006, 12:24 AM
Verndog's Avatar
2003 Toyota Tundra
That I believe is the root of the potential problem. And why I say that the tube spacer and washers are both undersize. There is alot of force put against that area, I could really see this after seeing the cracked washers, then looking over how the bar absorbs the side torsion. As you take a corner then hit a bump, you are hammering that side far more then the other. I believe that is how one side can shift, then crack and bend that washer, causing the whole setup to get mis aligned and loaded toward one side more then the other.
Since adding the Timbren load helpers, my truck can lean alot less on a corner now...also, I now believe after driving a couple of days, that this was the source of my suspension problem.
I will propably leave it off, till I can make my own thicker spacers, find a better neoprene dampener, and heavier washers. The axle end apears to be adequate, its the front body end mounting that takes the load and shock.
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
