This is a discussion thread titled "Thinking of lifting my truck...", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I have an 04 Dbl Cab 4x4 TRD that I am thinking about lifting. I have Ivan Stewart rims on it. I want to put 285's on it. Probably will not be doing much off road driving (mainly for looks). Will I be able to get the lift I need from either:
A. TUNDRA 2000 THRU 2006 4X4 V8 DOUBLE CAB OR ACCESS CAB 2 3/4in. LIFT WITH PRO COMP ADD-A-LEAFS AND DIFFERENTIAL DROP DOWN SPACERS http://extremetrucktoys.com/tun_lift_2.htm
B. Confed Suspension 2.5" complete lift kit http://www.cornfedsuspension.com/
I like the EZ lift becasue it seems easier to install (no spring compressor). I have used Cornfed before on my Tacoma but it was a PITA to use the spring compressor. But it worked good.
Or should I go with this:
C. Leave it alone (keep 265/75s on it with no lift).
i currently have the 2" cornfed on mine. i also have the 1/2" spacer that i never installed, since i didn't want to push the 2" mark much, and i didn't know about the diff drop kit back then or i would have done both.
my 285's fit fine. they slightly rubbed the mudflaps so i removed them. in normal driving they are no problem, but if you plan on going off road, they will rub if you hit a dip too hard.
i'm looking at my options to give just a bit more lift to avoid that rub.
i like the look much better even with stock tires. it sounds like the cornfed 2 1/2" might work well for you.
it will be a stiffer ride as opposed to coilovers, but it's a lot cheaper.
i hear ya about the spring compressors. if i added that 1/2" spacer too, then i wouldn't have to buy coilovers... decisions decisions....
Racerx, you have any pictures of your truck? Either kit, I will be putting the diff drop kit on. I just don't want to spend all that money and it turns out to rub or something.
it's not quite a sideshot, but it should do.
since this pic i added the black headlights too.
with the 2 1/2" kit and diff drop, you'll be good to go.
the only reason i'm looking into plan b at this point is i live off a dirt road and it can get pretty bumpy sometimes. some of the washes are pretty steep and if i hit them too fast it will rub.
on the road it's a nice ride and handles well in turns. never had any rubbing problems on pavement, even on bumpy roads with dips.
I would go with the EZ ride suspesion. Thats what I have in mine and it rides alot smoother than when I had just the front leveling kit in it. It looks great and still as somewhat of a stock ride to it. I run 285/75/16's under it with no rubbing problems. Good luck with your decision.
I found a member on the board who has the lift I like. TIE-YOTA has it. http://www.tundrasolutions.com/forum...pictures-lift/ 3" Toytec Lift with 1.5 AAL's in the back. Very nice looking. Now I have to get one more question answered before I get it. His truck has aftermarket rims on it. I have Ivan Stewart rims on mine. I guess it is a matter of offset. Will the 285s fit on my rims without hitting the control arms? If the tires don't fit, then I am just going to get a leveling lift and keep my 265/75s on it. Just got to finish my research and maybe somebody can answer my last question.
have you considered wheel adapters instead? only need one pair (for the front), they would give you an effective backspacing of i think 3.5" (i think stock is 5", but i'm not certain), and you can run the 285s without giving up your ivan rims. there is nothing wrong with running a 285 on a 7" rim...i'm running a 315 on an 8" rim. it just acts as a little bit of a beadlock.
the adapters are very sturdy. plenty of desert and trail guys use them. i got mine from aor4x4, around 200 bucks including shipping i think. 3.5" backspacing seems to be fine, plenty of guys here run 3.5" to fit 285 or 315 without hitting the uca or the frame.
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
