This is a discussion thread titled "Engine noise filtering through torn steering shaft boot?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
  #61 (permalink)
Old 08-21-2007, 01:26 PM
Garth's Avatar
Dealer : Handy Toyota
2000 Toyota Tundra,
- Other - 2002 Audi A6 Quattro
Garth's Photo Albums
Last Online: Yesterday 03:23 PM
Garth is on a distinguished road.
Default No, no luck yet...
I'm thinking of going the way of the nearby Indy auto repair shop... it looks so easy... but that rust is really being a pain.
-Garth
2000 Tundra SR5 Access Cab 4wd TRD V8 Cold Weather Pkg Drop-in Liner Towing Pkg Captains Chairs AM/FM/CD/Cass Stereo Westin Step Bars ARE CX Cap Remote Start/lock
2002 Audi A6 3.0L Quattro Tiptronic Cold Weather Pkg(4 heated seats) Leather Seats Sunroof AM/FM/Cass/CD Bose Stereo Xpel Clear Bra
  #62 (permalink)
Old 10-09-2007, 11:54 AM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
longwoodklon's Photo Albums
Last Online: Yesterday 03:20 PM
longwoodklon is on a distinguished road.
Default Re: Engine noise filtering through torn steering shaft boot?
Originally Posted by Garth View Post
I take the inner cover off (3 bolts) by the drivers feet, then carefully knocked the bushing down.
I mark the streering shaft where it connects by the rack and then disconnect it from the rack and remove the lower 1/2. The steering bushing should slide out the bottom under the truck.
I use a long extension to gentle tap the new one back into place.
Then reassemble everything.
Doesnt take but 15-20 minutes, but I have a hoist
My part came in, so now I'm trying to follow these directions, but have a question, where on the steering column did you disconnect it from the steering rack? at the four bolts right above the oil lines? Mine are all rusted, hitting them with WD-40 to soak now... then you must take the spline bolt off too, to get the seal off? It doesn't look like it'll go over the bracket for the steering rack.
-Garth
Thought I'd resurrect an old thread. Had this part for over a month, just this weekend got around to changing it out. Pretty easy following the above instructions and Mustangs picture and advice on getting the boot off the shaft. Hardest part was not mentioned in instructions though. The part about beating the crap out of the old seal to get it off. Not much room inside the cab to get a hammer on the old seal and it took so much force that it began to deform the old seal.
Got the new one in and you guys are 100% right. The ticking I used to hear on hard acceleration is gone. All I hear now is the rumble from the muffler. Best $16 I spent in a while.
edit: A side note. When I got the old boot off, the inner part was still stuck to the shaft. It seems that they used grease when they put it on at the factory, and over time the grease became like glue and held the boot which then created the tear. I cleaned the shaft so all old gunk was off it then just put the new boot on. Then from the inside and outside, I sprayed it with the Berrymans Silicone spray I picked up at Toyota. Is this what you guys would suggest? Did anyone use grease when putting on the new boot?
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 176k miles and counting......
  #63 (permalink)
Old 10-09-2007, 12:10 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 12:24 AM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
i know this thread pertains to the guys with rcd/tuff country/body lift, but what if your truck is SAS'd. I dont have a seal at all and there is a lot of noise coming through there. does anyone have an idea on how to fix this?
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
  #64 (permalink)
Old 10-09-2007, 01:10 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
I have never seen a SAS's truck that close so forgive the dumb questions.
How and /or where does your steering shaft come thru the firewall?
Can you take a picture of it so we can see? I dont understand how your steering connects thru the firewall and a picture may help me figure something for you. I want to see why the factory seal wont work.
Thanks
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
  #65 (permalink)
Old 10-09-2007, 01:16 PM
apimpdad's Avatar
2002 Toyota Tundra
Thanks
i will have to take a picture of it a little later, but pretty much the shaft comes out straight through the firewall. a hole was made for it to come out and go to the steering box, but i will get some pics of it later
Build Thread-
SAS on 02 Tundra
  #66 (permalink)
Old 10-09-2007, 01:21 PM
2002 Toyota Tundra,
OK, thanks
23 yrs with TOYOTA
K.I.S.S.
  #67 (permalink)
Old 10-09-2007, 02:43 PM
apimpdad's Avatar
2002 Toyota Tundra
got some pics for ya
this is how it was done, about a 1/4" rubber mat about 9" by 7" was placed over the hole with a hole in the rubber, and one of those gray pvc insulator tubes put on the steering shaft
this is with all that stuff removed
and 2 more
Build Thread-
SAS on 02 Tundra
  #68 (permalink)
Old 10-09-2007, 02:52 PM
2002 Toyota Tundra,
Thanks, but I will have to look tonight.
I am at work and they have a FIREWALL, so the pics and PHOTOBUCKET do not work here.
Stupid censorship
23 yrs with TOYOTA
K.I.S.S.
  #69 (permalink)
Old 10-09-2007, 10:23 PM
2002 Toyota Tundra,
couldn't you lay a bead off silicon sealer around the hole on the inside and out
23 yrs with TOYOTA
K.I.S.S.
  #70 (permalink)
Old 10-09-2007, 10:34 PM
apimpdad's Avatar
2002 Toyota Tundra
where you drew the red line is not really where the problem is, its where the shaft actually goes through the rubber mat. there is still a small void, about 1/8" to 1/4" around the shaft....
Build Thread-
SAS on 02 Tundra
  #71 (permalink)
Old 10-09-2007, 10:55 PM
2002 Toyota Tundra,
Gotcha
How about some sort of a CV boot over the shaft and secured to the rubber piece or the firewall.
Let me think about it for a while. I just got back from a funeral and my head isn't in the game tonight.
Maybe someone else has some better ideas.
What did JJC and Ted DO on their SAS's. I have seen TEDS (TMS2U)'s truck, but really didnt look at the steering shaft thru the firewall, so I dont remember.
23 yrs with TOYOTA
K.I.S.S.
  #72 (permalink)
Old 10-09-2007, 11:08 PM
apimpdad's Avatar
2002 Toyota Tundra
i will have to check with the other SAS rigs to see what they have, but the cv boot sounds like it might be a good idea.
Build Thread-
SAS on 02 Tundra
  #73 (permalink)
Old 11-15-2007, 09:20 PM
Cian's Avatar
Dealer : Elmhurst Toyota
Cian's Photo Albums
Last Online: Yesterday 11:30 PM
Cian is on a distinguished road.
This is a great thread.
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Hawk ceramic pads; Trfytoy window latches; Undercover tonneau
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD
  #74 (permalink)
Old 12-06-2007, 07:32 PM
DigitalFusion's Avatar
Dealer : Toyota City
DigitalFusion's Photo Albums
Last Online: 07-31-2008 03:51 PM
DigitalFusion is on a distinguished road.
Send a message via AIM to DigitalFusion
like a CV boot for an ATV, they are really cheap, and if you go to a atv place I bet you could measure several different ones for the best fit?
2001 Salvaged Tundra SR5 2WD Access Cab:
95% complete - Molly Grill, Color Matched Mirror Covers, Clear Turn Signal Lenses, Optima Red Top Battery,
XS Power headers,
Phillips Crystal Vision Bulbs, Detata Trax 18x9 wheels w/245-55-18 BFG GForce T/A's
Waiting to Install: Components for 3-4" front, 5-6" rear DIY lowering. (waiting on front struts)
  #75 (permalink)
Old 12-18-2007, 09:48 AM
Garth's Avatar
2000 Toyota Tundra,
Default My dealer charged me $252 to do this...
My local indy wouldn't touch it. I'm sick of the noise, and it's not budging for me. He said the 2 bolts on the steering shaft were rusted on so bad, they ended up having to cut them off, and put new one's in. But, it does sound so much better now! Thank goodness it's fixed finally!
