This is a discussion thread titled "Rear end blown..", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Well i guess my truck has finally failed me. I was lining up at a light and suddenly there was a terrible sequence of clicks coming from the rear of the truck, then all of a sudden Drive was useless!!!! It was hilarius since the truck is under a used-car warranty but it is not funny that I will end up with another open rear end. The truck is a stock peg leg and I'd ovbiously rather get the LSD installed than another POS open rear. Is there anyway to make it look like the truck had an LSD, or a way to get one installed instead?
Anyone else have rear end issues before? What generally happens when the open is blown? I'm not sure what all is broken. Thanks guys!
My Truck: 2000 Black TRD AC SR5
Is it a Toyota used "car" warranty? If so, obviously take it back and talk to them about replacing the 3rd member with an LSD. There may be an additional charge, but it sounds like it would be worth it to you. The spider gears in the rear diff are the weak link. Have you had your truck looked at yet?
My daily driver - 2008 Yaris sedan 'S'. Tinted windows in the rear, TRD anti-sway bar for the rear, 17" rims - Samurai SC02 Hyper Black. TRD lowering springs.
My favorite ride - a 2001 SR5 4x4. With - RCD 6" lift, JBA Titanium coated headers, JBA y-pipe, Unichip PnP, ARB rd-129 air locker (rear), Camburg UCA's, custom front Sway-A-Way coilovers, custom Sway-A-Way's with remote reservoirs and billet mounts for the hind-quarters, PolyPerformance limit straps with adjustable clevis's - mounts welded up by AJ at BentUp.com, Stubbs Welding rock sliders and custom front skid plate, 315/75/16 Toyo Open Country M/T's, on all 4 corners wrapped around 16x8 MB Motoring Blitz rims, cryo'd 4.88's set up by Inchworm Gear, Trenz billet grill upper, T-Rex billet grill lower, on board VI-AIR aircompressor and 3 gallon air tank from Wheelers Off-Road, Inc, AutoMeter A-pillar pod with transmission temp gauge (sending unit in the tranny pan), Long Tru-Cool LPD tranny cooler, 10" Flex-a-Lite tranny cooler fan w/thermostat, TRD billet oil filler cap, TRD air filter, TRD dual exhaust, and TRD add-a-leaf rear springs. Superlift TruSpeed Speedometer Recalibrator. Warn Trans4mer Grill Guard, brush guard and 9.5ti winch w/cover. Budbuilt traction bar. Wheelers Off Road Centric performance brake rotors: cross-drilled and slotted. Staun tyre deflators set for 13 psi. Our home away from home, 2004 Outback 26RS travel trailer with 15" MB Motoring Blitz rims to match the Tundra.
Same thing happened to me about 6 months ago (84,000 miles). I was driving to class, hit a bump, heard a loud pop and horrible metal on metal grinding. Had the truck towed to the dealership. After the tech determined it was the rear differential, he opened it up to find teeth missing from the main gears, and large chunks of metal laying in the bottom of the differential.
Didn't have a warranty, so to get a brand new rear diff installed, it was over $2,400.
Now I have issues in cooler weather with having to rev the engine in order to move which is either the rear diff again, or the tranny. Taking the truck in later this week to get it checked out.
I'm a little late to this thread but hoping for some opinions. 2000 taco,V6, TRD. About a month or less of howling from the rear diff and the dealer diagnosed it as needing a new 3rd member. $2250.00
If this is a weak link, any recommendations on an upgrade or aftermarket solution? I'm not concerned so much about keeping the electric locker but still want at least an LSD. Thanks?
For that price you can get a better traction system. Contact MarlinCrawler.com or Inchwormgear.com for your options.
I agree 100% with Mike...
Look for a non-TRD Tacoma 3rd member, or the 3rd from any 1st-gen Tundra, and have an autolocker or an ARB installed.
