Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Any benefit to rear sway bar disconnects w/ IFS?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-22-2006, 05:03 PM
Dealer : Big Two Toyota
- Other -,
2003 Toyota Tundra WHITE AC TRD
mitchinphx's Photo Albums
Last Online: 03-06-2007 04:52 PM
mitchinphx is on a distinguished road.
Default Any benefit to rear sway bar disconnects w/ IFS?
i've always had solid axle jeeps w/ sway bar quick discos. do the rear mounted sway bars on our tundras limit the suspension travel any when on the trail?
Old 06-22-2006, 05:19 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 11:42 AM
Default Re: Any benefit to rear sway bar disconnects w/ IFS?
yes they do, and leaving the bar connected offroad is a great way to bend it.
brian at front range offroad sells very high quality discos, frontrangeoffroadfab.com
-s
GFX by FreedomEagle50
Manual Hubs
WTB: Passenger side headlight housing and signal light housing, OEM Toyota, for 2000 Tundra
Old 06-22-2006, 05:36 PM
- Other -,
-s
thank you very much. i planned on implememting discos on the rear but wasn't sure if the front was limited all that much.
Old 06-23-2006, 07:36 AM
the front doesnt change much.
Manual Hubs
Old 06-25-2006, 01:42 PM
BlueRanger's Avatar
Dealer : Toyota Carlsbad
2004 Toyota Tundra
BlueRanger's Photo Albums
Last Online: 09-02-2008 08:47 AM
BlueRanger is on a distinguished road.
Send a message via AIM to BlueRanger
I beg to differ, I always disconnect when I hit the dunes with my donahoes, makes such a difference if your hitting anything sideways. Street wise there is more body roll, but it "holds" once you reach a certain point. I love it disconected on the street when I hit driveways at an angle, because instead of your truck tossing you it just plops right in, very smoothly.
04 Tundra, Hoes, Uni's, Spintech, 285s + other misc. bling items.
Old 06-14-2007, 12:39 PM
Tundradrenalin's Avatar
My eBay Tundradrenalin's Photo Albums
Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.
bumping old threads.... woot!
I've been doing my homework on swaybars and have read enough to understand the good points to using an anti-sway bar and the bad points to overcompensating the sway and why I don't want the bar hooked up while on the trail. Reducing camber on corners is a benefit to anyone taking a turn over 10mph. I really hate feeling like I'm going to fall out of my door if I don't hold on to my armrest when making a hard right. But slamming a rock on one side and feeling it as an 8" speedbump, I don't want either.
If I get a hellwig or something like it, I'm also going to want a disconnect kit from somewhere like frontrangefab. The kit costs 3/4 as much as the swaybar kit and they say you replace everything but the bar itself. Uhh...
You think I could pick up a bar from a junk yard or have one fab'd for me for cheaper than the whole kit? After install of your bar and install of the disconnect, you have a lot of extra parts now right?
Or do I even need the disconnect? My truck doesn't see many trails in southeast VA, it does see a lot of beach and deep sand though.
This is a worthwhile mod from the reviews, but does the gain outweigh the loss?
Thanks for reading.
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
My Truck:
Old 06-18-2007, 09:50 AM
Honestly for beaches, dunes and fire roads, the swaybar won't hold back a stock travel front end.
Manual Hubs
Old 08-19-2007, 09:30 PM
fastman9's Avatar
fastman9's Photo Albums
Last Online: 08-30-2008 11:19 AM
fastman9 is on a distinguished road.
So would you recommend disconnecting the Hellwig if you have 2.5 Teamwest up front and soon Bilsteins and AAL 3 pack from Donahoe in the back?
Old 08-20-2007, 10:04 AM
From my own personal experience...I probably didn't notice the front swaybar much, since when I was running harder trails the truck was pretty heavy.
2"-2.5" adjustment to the ride height isn't going to hurt. If you're regularly going offroad, or go higher than 2.5" or so, the end links will slowly take a bend and will eventually break if you don't put a heim joint (or something) at the upper end of the link. Both mine were bent, a few guys have broken theirs.
If you have uniballs, get/make disconnects for the front or remove the swaybar if you're usually offroad.
If you don't go offroad, there's no need to disconnect the rear swaybar at all. If you do go offroad, suck it up and get the FROR discos or make your own. The FROR kit doesn't AFAIK replace the brackets or the u-bolts, just the end links.
Manual Hubs
Similar Threads for: Any benefit to rear sway bar disconnects w/ IFS?
Daystar Sway Bar Bushings, What kind of Noise? keninsb Suspension & Axle 8 01-05-2004 09:48 PM
Hotchkiss Sway Bar? gforeman Handling Improvements 7 12-13-2003 08:02 AM
Rear Sway Bar TetTundra Suspension & Axle 8 05-25-2003 03:45 PM
Rear Sway Bar kornkid 1Gen-Sequoia 5 04-23-2003 08:18 PM
Sway Bar ChuckFundra Handling Improvements 175 06-06-2002 01:06 PM
