This is a discussion thread titled "Does Anyone Know Where I Can Get Stock Bolts And Dish Washers For Stock Ucas?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I'm having my RCD lift installed as we speak, and I don't have the stock bolts and washers that go with my stock ucas. Does anyone know where I could find these. Most likely someone that intalled new ucas. I kept them when I put my coilovers and camburg ucas on, but I just can't find them anywhere.
Re: Does Anyone Know Where I Can Get Stock Bolts And Dish Washers For Stock Ucas?
I reused my stock bolts, washers and nuts with my camburg ucas, as did most everyone that I know of, too.
__________________ My 03 Tundra v6 AC SR5 mods:URD lightened crankshaft pulley(soon) | Xtreme Alloy 1079 | 285/75-16 BFG's | Spintech ProStreet dumped | Total Chaos str/rck bushings |Camburg UCAs| TRD 4X4 v8 coil | Daystar 2.5" spacers | TRD yellow-blue shocks | 5100's |No-Slip Locker w/Mobile1 synthetic dif. oil | B&M transmission cooler | 911 performance brake pads | Hellwig swaybar(need quick disconnects) | Front seat covers | 35% Tint 2 front windows | Drop-in bed liner | clear-red-clear tail lights | Clear corners | AMI 21" polished antenna | Challenger steps | Toyota skid plate | Demello bed bar w/ cheapo fogs re-wired and running 100w H3's | Color matched mirror covers| Debadged | PermaShield teflon
This is for the RCD lift. I'm going back to the stock ucas, and the stuff I used for my camburg ucas won't fit. What I really need is the 8 "bellied" washers (4 on each side), the bolts, 1 eccentric (not sure on spelling) bushing for the lower control arm, that is for the front end alignment. There are 4, but we had to use the torch on one to get it out.
Go to the dealer or find a dealer online and have them overnighted. Salvage yards won't spend the time to remove nuts and bolts unless you buy the whole control arm.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 Revos on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Aero 2525 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate, EBC "green" brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Wheeler's polyurathane front swaybar bushing kit,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Silverstar fog light bulbs, , Viair 300P air compressor
Wish list: Line X'd front and rear bumper, rock sliders
imdone is completely correct...read through the rcd lift stickies, they talk about it there.
as for your lower control arm, the cam is a separate piece from the arm/bushing assembly; the bushing is centered in the arm, so you should be able to get a replacement from daystar or wherever. if you do, it'll probably be poly not oem rubber (or whatever they use), so you may want to burn & change all four lca bushings.
i thiink i might have someone's old lcas sitting around. jons are on my truck now, tedds are in the garage i think. my cams froze, had to cut them loose and needed to replace the lcas.
