This is a discussion thread titled "Steering noise after lift install", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-27-2006, 09:00 PM
Dealer : Toyota of Santa Barbara
2004 Toyota Tundra
kona66's Photo Albums
Last Online: 05-29-2007 10:52 AM
kona66 is on a distinguished road.
Default Steering noise after lift install
I recently installed Camburg coilovers and UCA s on my 2004 D Cab 2wd. After about a month my steering has developed a definate groaning sound and an almost grating feel coming through the steering wheel. Power steering fluid level is fine. Has anyone else experienced this?
Old 07-28-2006, 01:11 AM
gypsy cab driver's Avatar
Dealer : Penske Toyota
2005 Toyota Tundra
gypsy cab driver's Photo Albums
Last Online: 09-17-2007 02:52 PM
gypsy cab driver is on a distinguished road.
Default Re: Steering noise after lift install
clean the uniballs and lube with triflow.
___________________________________
Old 08-10-2006, 09:22 PM
Dealer : Frontier Toyota
TUNDRASCRIP's Photo Albums
Last Online: 08-10-2006 09:54 PM
TUNDRASCRIP is on a distinguished road.
Clean upper and lower uniballs. Actually the best thing to do is to replace all four and call it a day. It might run about 400 or so but the ball joints come pre lubed with factory seeled boots. Press them in and your done. As long as you don't mess with lower A-arms or tie rods you shouldn't need an allignment.
Old 08-13-2006, 01:34 PM
2005 Toyota Tundra
he shouldnt need to replace anything,i had the same problem.just clean out the uniballs with a hose,wipe and lube with trin flow.keep in mind you will have to keep doing this,since the sound does come back.
Old 08-13-2006, 11:52 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
Last Online: Today 11:14 AM
mustang67408 will become famous soon enough.mustang67408 will become famous soon enough.
Turn up the radio. As everyone has said: you can clean the uniballs and lube them, BUT the noise will return. Thats a fact your going to have to live with.
I have tried everything, from lubes,spray graphit,silicon sprays, silicon paste to loosening the bolt holding them together to the point that the bolt was loose. THEY MAKE NOISE.
I tightened them back up to my liking , since there is no spec and learned to live with it. Its a truck.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Old 08-14-2006, 12:27 AM
2005 Toyota Tundra
you also might want to tighten your uca bolt everyso often.mine keep coming loose after a few weeks.
Similar Threads for: Steering noise after lift install
Noise and vibration in steering wheel cleanb13 Suspension & Axle 1 03-07-2006 01:55 AM
need help with lift install TundraDog Suspension & Axle 0 01-02-2006 09:09 PM
Install steering wheel with audio controls ando1 Audio & Stereo 1 08-08-2005 05:26 PM
good shop to install lift louisha Suspension & Axle 1 07-23-2005 09:38 PM
Thud Noise while steering 2DaMax Engine & Drivetrain 9 12-05-2002 04:35 PM
